Intel® C++ Compiler
7877 Discussions
ERROR while installing ICC 11.1 on Ubuntu 12.04 LTS Precise Pangolin
Sriram_M_Intel
Hi, I am wondering if there is any support for ICC 11.1 on Ubuntu 12.04 LTS. Since the Ubuntu distro is the latest, and ICC 11.1 is one generation old, I am not sure if it is still supported. I cannot use a different version of ICC for my project/ downgrade my distro at this point of time. That is why I posted this thread on the forum.
The error is least descriptive: Step no: 4 of 7 | Installation configuration - Missing Critical Pre-requisite -------------------------------------------------------------------------------- There is one or more critical unresolved issue which prevents installation to continue. You can fix it without exiting from the installation and re-check. Or you can quit from the installation, fix it and run the installation again. -------------------------------------------------------------------------------- Missing critical pre-requisite -- 32-bit libraries not found This product release requires the presence of 32-bit compatibility libraries when running on Intel 64 architecture systems. One or more of these libraries could not be found: libstdc++ libstdc++5 glibc libgcc Without these libraries, the compiler will not function properly. Please refer to Release Notes for more information.
I have verified that I have all possible 32-bit packages installed on my machine (since I upgraded to Ubuntu 12.04 from 11.04)
For example: I have:
dpkg -l | grep -e ia32 -e stdc++ -e glib -e libc -e libgcc ii ia32-libs 20090808ubuntu35 ia32 shared libraries - transitional package ii ia32-libs-multiarch:i386 20090808ubuntu35 Multi-arch versions of former ia32-libraries ii libc-bin 2.15-0ubuntu10 Embedded GNU C Library: Binaries ii libc-dev-bin 2.15-0ubuntu10 Embedded GNU C Library: Development binaries ii libc6 2.15-0ubuntu10 Embedded GNU C Library: Shared libraries ii libc6:i386 2.15-0ubuntu10 Embedded GNU C Library: Shared libraries ii libc6-dev 2.15-0ubuntu10 Embedded GNU C Library: Development Libraries and Header Files ii libc6-dev-i386 2.15-0ubuntu10 Embedded GNU C Library: 32-bit development libraries for AMD64 ii libc6-i386 2.15-0ubuntu10 Embedded GNU C Library: 32-bit shared librar ii libglib2.0-0 2.32.1-0ubuntu2 GLib library of C routines ii libglib2.0-0:i386 2.32.1-0ubuntu2 GLib library of C routines ii libglib2.0-bin 2.32.1-0ubuntu2 Programs for the GLib library ii libglib2.0-cil 2.12.10-2ubuntu4 CLI binding for the GLib utility library 2.12 ii libglib2.0-cil-dev 2.12.10-2ubuntu4 CLI binding for the GLib utility library 2.12 ii libglib2.0-data 2.32.1-0ubuntu2 Common files for GLib library ii libglib2.0-dev 2.32.1-0ubuntu2 Development files for the GLib library ii libglibmm-2.4-1c2a 2.32.0-0ubuntu1 C++ wrapper for the GLib toolkit (shared libraries) ii libstdc++5 1:3.3.6-25ubuntu1 The GNU Standard C++ Library v3 ii libstdc++5:i386 1:3.3.6-25ubuntu1 The GNU Standard C++ Library v3 ii libstdc++6 4.6.3-1ubuntu5 GNU Standard C++ Library v3 ii libstdc++6:i386 4.6.3-1ubuntu5 GNU Standard C++ Library v3 ii libstdc++6-4.4-dbg 4.4.7-1ubuntu2 GNU Standard C++ Library v3 (debugging files) ii libstdc++6-4.4-dev 4.4.7-1ubuntu2 GNU Standard C++ Library v3 (development files) ii libstdc++6-4.6-dev 4.6.3-1ubuntu5 GNU Standard C++ Library v3 (development files) ii libgcc1 1:4.6.3-1ubuntu5 GCC support library ii libgcc1:i386 1:4.6.3-1ubuntu5 GCC support library ii libgcc1-dbg 1:4.6.3-1ubuntu5 GCC support library (debug symbols) ii libgcc1-dbg:i386 1:4.6.3-1ubuntu5 GCC support library (debug symbols)
If some developer can have a look at it during free time, it would be of great help. Since Ubuntu 12.04 has long term support, it would be very valuable to fix this issue.
Ram
SSG/DPD/ECDL
aazue
Hi
Maybe require package ia32-libs-dev ??
aazue
Hi
More complete ...
I have to my hand is Debian but are aproximately same with Ubuntu
ii ia32-libs 20120102 ia32 shared libraries for use on amd64 and ia64 systems
ii ia32-libs-dev 20120102 ia32 development files for use on amd64 and ia64 systems
ii klibc-utils 1.5.20-1+squeeze1 small utilities built with klibc for early boot
ii lib32stdc++6 4.4.5-8 The GNU Standard C++ Library v3 (32 bit Version)
ii libc-bin 2.11.3-2 Embedded GNU C Library: Binaries
ii libc-dev-bin 2.11.3-2 Embedded GNU C Library: Development binaries
ii libc6 2.11.3-2 Embedded GNU C Library: Shared libraries
ii libc6-dev 2.11.3-2 Embedded GNU C Library: Development Libraries and Header Files
ii libc6-dev-i386 2.11.3-2 Embedded GNU C Library: 32-bit development libraries for AMD64
ii libc6-i386 2.11.3-2 Embedded GNU C Library: 32-bit shared libraries for AMD64
ii libcairo2 1.8.10-6 The Cairo 2D vector graphics library
ii libcairo2-dev 1.8.10-6 Development files for the Cairo 2D graphics library
ii libcap-ng0 0.6.4-1 An alternate posix capabilities library
ii libcap2 1:2.19-3 support for getting/setting POSIX.1e capabilities
ii libcdt4 2.26.3-5 rich set of graph drawing tools - cdt library
ii libcomerr2 1.41.12-4stable1 common error description library
ii libcompfaceg1 1:1.5.2-5 Compress/decompress images for mailheaders, libc6 runtime
ii libconsole 1:0.2.3dbs-69.1 Shared libraries for Linux console and font manipulation
ii libcroco3 0.6.2-1 a generic Cascading Style Sheet (CSS) parsing and manipulation toolkit
ii libcups2 1.4.4-7+squeeze1 Common UNIX Printing System - Core library
ii libcupsimage2 1.4.4-7+squeeze1 Common UNIX Printing System - Raster image library
ii libcurl3 7.21.0-2.1+squeeze1 Multi-protocol file transfer library (OpenSSL)
ii libcurl3-gnutls 7.21.0-2.1+squeeze1 Multi-protocol file transfer library (GnuTLS)
ii libcurl4-openssl-dev 7.21.0-2.1+squeeze1 Development files and documentation for libcurl (OpenSSL)
ii libcwidget3 0.5.16-3 high-level terminal interface library for C++ (runtime files)
ii libdbus-glib-1-2 0.88-2.1 simple interprocess messaging system (GLib-based shared library)
ii libgcc1 1:4.4.5-8 GCC support library
ii libglib2.0-0 2.24.2-1 The GLib library of C routines
ii libglib2.0-data 2.24.2-1 Common files for GLib library
ii libglib2.0-dev 2.24.2-1 Development files for the GLib library
ii libklibc 1.5.20-1+squeeze1 minimal libc subset for use with initramfs
ii liblocale-gettext-perl 1.05-6 Using libc functions for internationalization in Perl
ii libpthread-stubs0 0.3-2 pthread stubs not provided by native libc
ii libpthread-stubs0-dev 0.3-2 pthread stubs not provided by native libc, development files
ii libstdc++6 4.4.5-8 The GNU Standard C++ Library v3
ii libstdc++6-4.4-dev 4.4.5-8 The GNU Standard C++ Library v3 (development files)
ii linux-libc-dev 2.6.32-41 Linux support headers for userspace development
Hubert_H_Intel
What you need to install for ICC11.1 is the compatibility library libstdc++5 and if you develop 32-bit apps the 32-bit libraries, for example:
$ sudo apt-get install libstdc++5
$ sudo apt-get install ia32-libs
TimP
Black Belt
For the old 64-bit compilers, you will need both the 32- and 64-bit libstdc++-5 even if you develop for 64-bit mode only. It's certainly easier to use a version of the compiler which is set up for recent versions of your OS.
