Installing parallel_studio_xe_2011_sp1_update1_intel64.tgz (after failing on install of 32-bit/64-bit).
The 32-bit only install went well (had to uninstall failed install too)
Now my remaining problem is the Eclipse Integration is failing.
Eclipse 8, Ubuntu 11.10, x64
Following instructions, Eclipse cannot successfully Add Local
Work with: file:/opt/intel/composer_xe_2011_sp1.7.256/eclipse_support/cdt8.0/eclipse/
In the Name checkbox list
[ ] (i) There are no catagorized items
Is there a missing file?
Jim Dempsey
Jim Dempsey
Hello Jim,
please uncheck check box Group items by category after having added the plug-in:
You should see the three plug-ins from the screenshot then.
Georg Zitzlsberger
Georg Zitzlsberger
- « Previous
- 1
- 2
- Next »
Hello Daniel,
do you have something in mind why you want to provide different options to the debugger engine?
Or are we speaking about arguments that should be provided/passed to the application you're debugging (debuggee)?
You can also create a command file for commands to be executed each time you start-up the debugger (e.g. run to a certain location).
Let me assure you that setting "-gdb" does not make sense in the Eclipse plug-in configuration at all. Except you want to break the communication between Eclipse & debugger back-end.
Georg Zitzlsberger
Georg Zitzlsberger
- « Previous
- 1
- 2
- Next »
