Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
7677 Discussions
Effective tool for run-time errors and memory leaks detection
leps
Hi!
Created application is working toooo slow, looks like there are a lot of memory leaks, there are a lot of pointers. So, please, can you advice some effective tool for run-time errors and memory leaks detection in Visual Studio C++?
JenniferJ
Try out the Intel Parallel Inspector or Intel Inspector XE.
The eval link is below.
The Intel C++ Composer XE provides a Static Security Analysis (SSA) and it will analyze your code during compilation time. But you need the Inspector XE to view the result.
Jennifer
