Intel® C++ Compiler
7833 Discussions
Efficient use of enhanced rep movsb/stosb with an unaligned destination address
Hani_Deek
This question is about assembly code.
Many people believe that the implementation of 'enhanced rep movsb/stosb' obtains an aligned address internally before it starts moving data in large chunks, which means that it is unnecessary for us to write code to align the destination address before passing it to the operation.
However, the language of the Intel optimization manual, as well as some other things that I have read online,  make me unsure about this point. It could be more efficient to write code to do unaligned moves separately and then pass a 16-byte aligned address to 'rep movsb/stosb' .
When using enhanced 'rep movsb/stosb' with an unaligned destination address, is it more efficient to rely completely on the hardware implementation, or should I write code to pass an aligned address to the operation?
jimdempseyatthecove
Black Belt
With (arbitrary) unaligned source and destination addresses, there is no assurance that extent of the unalignment of the source matches the extent of the unalignment of the destination, and thus one cannot assume you can ever coordinate source and destination alignment.
The newer CPU designs are intended to take mismatched alignment issues into consideration (abstractly through pipelining where the input port and output port of the pipeline can be out of phase).
Probably yes. This would depend on if you intend to use the copied data later with SIMD instructions,
Probably no, if you are simply moving text about (e.g. in a text editor)
Jim Dempsey
jimdempseyatthecove
Black Belt
Jim Dempsey
PrasanthD_intel
Jim seems to have answered your question.
Do let us know if all your queries were resolved.
Prasanth
PrasanthD_intel
Thanks for Marking the solution.
This issue has been resolved and we will no longer respond to this thread. Please start a new thread if you require additional assistance from Intel. Any further interaction in this thread will be considered community only.
Prasanth
