Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7731 Discussions
Elemental functions in template classes
Sebastian_R_1
I just figured out that you can not call math functions when combining elemental functions and template classes:
[cpp]#include <cmath>
template<typename T>
class A {
public:
__attribute__((vector))
T b(T value)
  return std::sqrt(value);
int main()
   A classA;
   float b = 4;
   classA.b(b);
} [/cpp]
Error message:
[plain] asdf.cpp(13): error #2593: indirect call is not supported in vector function
          ^ [/plain]
Compiler version:
[plain]icpc (ICC) 12.1.5 20120612
Copyright (C) 1985-2012 Intel Corporation. All rights reserved. [/plain]
I can work around this problem using typedefs, but it would be nice to support this with templates as well.
SergeyKostrov
Valued Contributor II
Did you try to compile your test-case without '__attribute__( ( vector ) )' for the function 'b'?
Sebastian_R_1
Yes, works fine.
Judith_W_Intel
I see this error in an older version of 12.1. It looks like this was fixed in early August 2012 as our DPD200235034 in both 12.1 and 13.0. Please upgrade to a new version and sorry for the inconvenience. Judy
