I'd like to report an issue with Intel C++ compiler output for Debug configurations ( 32-bit & 64-bit ): There are empty lines and please take a look ( I marked empty lines with * empty * label ):
[ Intel(R) C++ Compiler XE 13.0.0.089 [IA-32] - Debug - There are empty lines ]
------ Build started: Project: IccTestApp, Configuration: Debug Win32 ------
Compiling with Intel(R) C++ Compiler XE 13.0.0.089 [IA-32]... (Intel C++ Environment)
Stdphf.cpp
IccTestApp.cpp
Compiling manifest to resources... (Microsoft VC++ Environment)
Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1
* empty *
Copyright (C) Microsoft Corporation. All rights reserved.
* empty *
* empty *
Linking... (Intel C++ Environment)
xilink: executing 'link'
Creating library ..\Debug\IccTestAppD.lib and object ..\Debug\IccTestAppD.exp
Embedding manifest... (Microsoft VC++ Environment)
* empty *
* empty *
* empty *
IccTestApp - 0 error(s), 0 warning(s), 0 remark(s)
========== Build: 1 succeeded, 0 failed, 1 up-to-date, 0 skipped ==========
[ For comparison this is the output from Microsoft C++ compiler - Debug - No empty lines ]
------ Rebuild All started: Project: ScaLibTestApp, Configuration: Debug Win32 ------
Deleting intermediate and output files for project 'ScaLibTestApp', configuration 'Debug|Win32'
Compiling...
Stdphf.cpp
Compiling...
ScaLibTestApp.cpp
Linking...
Creating library Debug/ScaLibTestAppD.lib and object Debug/ScaLibTestAppD.exp
ScaLibTestApp - 0 error(s), 2 warning(s)
========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==========
Note: I don't consider these empty lines as a significant issue but it affects some Output Parsing software subsystem. Thanks in advance.
Could you please specify Visual Studio version?
I saw the issue, it's not so bad. It separates out the MS tools' output. It's pretty minor.
I will file a low bug report.
Jennifer
Hi Sergey,
Update to this issue: those extra empty lines are from msvc's resource compiler. so we can not remove it easily, and will not be fixed.
Jennifer
