Intel® C++ Compiler
Error 04010002_1670, what's that?
kalfelz__guilherme
I can't find any information on error 04010002_1670, this happens when I try to compile the JUCE framework using the Intel Compiler. And no error appears when I use MSVC compiler instead.
My extra command line stuff:
/Qip /Qftz /Qopt-matmul /Quse-intel-optimized-headers /O3 /Qprec-div- /fp:fast=2 /QxSSE3 /Qinline-factor:200 /Qopt-report:4 /Qopt-report-phase ipo /Qparallel
Using Intel MKL=Parallel and ILP64
Here's the partial error log.
1>(192) (col. 5): : error : 04010002_1670
This happens on the file include_juce_core.cpp
Here's the optrpt file dump start
    Report from: Interprocedural optimizations [ipo]
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.0.120 Build 20180804
Compiler options: /c /Qm64 /IC:\Work Ready\VST_SDK\VST3_SDK /I..\..\JuceLibraryCode /I..\..\JuceLibraryCode\modules /IC:\Work Ready\VST SDK 2.4 (r2) /Zi /nologo /W4 /MP /Ox /D:__INTEL_COMPILER=1900 /D:MKL_ILP64 /D:_CRT_SECURE_NO_WARNINGS /D:WIN32 /D:_WINDOWS /D:NDEBUG /D:WSV8 /D:WSV9 /D:WEVE /D:W64 /D:ONE_STEREO_OUTPUT_ONLY /D:JUCE_WINDOWS /D:JUCER_VS2017_78A5024=1 /D:JUCE_APP_VERSION=1.0.0 /D:JUCE_APP_VERSION_HEX=0x10000 /D:JucePlugin_Build_VST=1 /D:JucePlugin_Build_VST3=1 /D:JucePlugin_Build_AU=0 /D:JucePlugin_Build_AUv3=0 /D:JucePlugin_Build_RTAS=0 /D:JucePlugin_Build_AAX=0 /D:JucePlugin_Build_Standalone=0 /D:JucePlugin_Build_Unity=0 /D:JUCE_SHARED_CODE=1 /D:_LIB /EHs /EHc /MD /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /std:c++14 /Fo.\WusikEVEV564\Shared Code\ /Fd.\WusikEVEV564\Shared Code\\Wusik Engine_SharedCode.pdb /TP /FC /Qftz /Qopt-matmul /Quse-intel-optimized-headers /O3 /Qprec-div- /fp:fast=2 /QxSSE3 /Qinline-factor:2 /Qopt-report:4 /Qopt-report-phase:ipo /Qparallel
  WHOLE PROGRAM (SAFE) [EITHER METHOD]: false
  WHOLE PROGRAM (SEEN) [TABLE METHOD]: false
  WHOLE PROGRAM (READ) [OBJECT READER METHOD]: false
INLINING OPTION VALUES:
  -Qinline-factor: 2 (user-specified)
  -Qinline-min-size: 30
  -Qinline-max-size: 4 (user-specified)
  -Qinline-max-total-size: 40 (user-specified)
  -Qinline-max-per-routine: 200 (user-specified)
  -Qinline-max-per-compile: 10000 (user-specified)
In the inlining report below:
   "sz" refers to the "size" of the routine. The smaller a routine's size,
      the more likely it is to be inlined.
   "isz" refers to the "inlined size" of the routine. This is the amount
      the calling routine will grow if the called routine is inlined into it.
      The compiler generally limits the amount a routine can grow by having
      routines inlined into it.
Begin optimization report for: fabsl(long double)
DEAD STATIC FUNCTION: (fabsl(long double)) C:\PROGRA~2\INTELS~1\COMPIL~1\windows\compiler\include\math.h(955,3)
Viet_H_Intel
Seems like compiler encounters an internal error. Can you create a preprocess file (include_juce_core.i) and report it to http://www.intel.com/supporttickets?
Viet
Viet
kalfelz__guilherme
Oh, I have to check how I do that, thanks.
Cheers, WilliamK
kalfelz__guilherme
Done, I used /P to generate the file and created a ticket. Thanks. :-)
Cheers, WilliamK
kalfelz__guilherme
Well, here's the fun thing. For now I can compile the file that is producing the error with Qipo and it compiles, them I use the obj file and add to my project, as I can't use Qipo on my whole project as I have way too many files. ;-) Still, Intel is looking into the error code...
Cheers, WilliamK
