I've recently decided to switch from C++ AMP to OpenMP. After installing the ICC I'm getting an error "could not checkout FLEXlm license". I googled for a solution but there doesn't seem to much recommended. I tried registering the Parallel Studio in hopes that would install the license file correctly. Any suggestions? Thanks in advance!
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Do you remember where you stored your license file? What were all the paths that ICC was searching for the license file?
could not checkout FLEXlm license in c++ compiler, its a serious issue in this processor. printer offline fix helps you to get the detail of this.
