I am trying to compile an original VC based project on Intel compiler. I have kept -Werror option ON treating warning as errors.
I am getting an error
"error #2259: non-pointer conversion from "unsigned __int64" to "UINT32={unsigned int}" may lose significant bits" for the following code snippet.
struct_array[count].var_32 = (uint32) GET_2BYTE(var_64,__no).
GET_2BYTE macro is defines as below:
#define GET_2BYTE(__word, __no) (((__word) >> ((__no) * 16)) & 0xFFFF)
So, I am trying to typecast a 64 bit variable into 32 bit.
I assume macro is not a reason for this warning/error as it is just creating an offset.
Is there any way to avoid this error without turning of -Werror option.
// testcase U81090
typedef unsigned int uint32;
struct node {
int var_32;
int y;
int main()
int count;
node struct_array[100];
long long var_64 = 300;
int __no = 4;
for (int i = 0; i < 100; ++i)
struct_array.var_32 =i;
struct_array.y = i+100;
count = 5;
struct_array[count].var_32 = (uint32) GET_2BYTE(var_64,__no);
return 0;
I could compile the above code segment as below:
c:\>icl -c tstcase.cpp
Intel C++ Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.1.127 Build 20101116
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
tstcase.cpp
The macro seems working. My data types may be different from yours. Could you please let me if I am missing something here.
( Error #2259 )
i have your sample tstcase.cpp compile with the Intel C++ 12.0 (XE) on openSUSE 11.4 RC 2 64 Bit Linux,
turned all Warning Flags, with the icpc the compled compile correct, no errors no critical warnings
i think thats a problem from environment (OS ) or both OS and Compiler
regards
Franz
What is your environment to in the original issue?
my Environment is :
operating System: openSUSE 11.4 RC 2 64 Bit Linux
Hardware: ASUS Sabertooth X58
Processor: Intel i7-950
RAM : 8 GByte
Developing Environment: Intel Parallel Studio XE update 1 intel64 and Composer XE update_1 intel 64
best regards
Franz
Even I have written a small test program and it works without any warnings.
So, I tweaked the troublesome code to following.
local_var_64 = GET_2BYTE(var_64,__no)
struct_array[count].var_32 = (uint32) local_var_64 and it works.
This is very weird. I never expected it to work. (It was a desparate attempt with no logic). Now I am not sure why compiler is allowing this.
One more thing I have noticed is that it only happens when I am typcasting 64bit to something else. Other typecastings look good.
My build environment is:
Windows 7 64 bit
VC 2005 with Intel C++ Intel 64 Compiler XE on Intel 64, Version 12.0.2.154 Build 20110112.
I can't use this stupid solution. Is there any other way to find the root cause.
Abhi
Happy to learn that you found the workarround.
Can you try attached code snippet with compilation options in the batch files and let me know if you can reproduce it.
The warning is correct for your test case.
C:\>icl -c /Wp64 warning.c
warning.c
warning.c(10): warning #2259: non-pointer conversion from "unsigned __int64" to
"unsigned int" may lose significant bits
local_node.var_32 = (unsigned int) (y & 0xFFFF);
You are using /WX option. This option forces compiler to convert warnings into errors.
