Dear all:
I download Intel Composer XE 2013 SP1 and installed with proper serial number. While building the application in VS2012 using the inter compiler facing the following error:-
Error: A license for CComp is not available (-5,357).
1>
1> Make sure that a license file is being used that contains a license
1> for the requested feature. If your license requires a license server,
1> make sure that the server is using the right license file (usually,
1> this would be the same license file that is being used by this
1> application), and make sure that you have not changed the license
1> file since starting the server.
1>
1> License file(s) used were (in this order):
1> 1. Trusted Storage
1> 2. C:\Program Files\Common Files\Intel\Licenses\w_XXXXXXXX.lic
1> 3. C:\Program Files (x86)\Common Files\Intel\Licenses
1> 4. C:\PROGRA~1\Intel\COMPOS~1\bin\ia32\*.lic
1>
1> Please visit http://software.intel.com/sites/support/ if you require technical assistance.
1>
1>icl : error #10052: could not checkout FLEXlm license
As I saw in intel site, there are people who faced this issue but re installation and reboot the system fixed this issue. But i tried and didn't work for me. Does anyone have any idea how to fix this?
Thanks in advance.
The site is blocking attempts to answer here. possible alternative is to ask on the companion licensing and registration forum
If you have the license which should have been emailed to you, copy it to the path mentioned at 3. alternate is to register your serial on the registrationcenter dot intel dot com site and request a fresh one.
Can you provide your serial number in a private message to me ? i'd like to have a check then.
Thank you.
QIAOMIN.Q
Intel Developer Support
User forums: http://software.intel.com/en-us/forums/
