I am trying to compile VTK (www.vtk.org) with ICC on OS X 10.4.11. I have the latest ICC (10.1.009) installed. The errors can be found here:
The problem code seems to be a template function in the vtkVarient.cxx code.
That source file can be found here:
The offending method is ToNumeric(...).
The compile will succeed in Debug mode (-gdwarf-2) but fail in "Release" mode (-03).
The compile also fails on Linux 64 using the latest ICC for Linux.
Could someone help me figure out what the problem is? This same code seems to compile with GCC, VS2003, VS 2005, xlC, Borland, cygwin and MinGW.
Mike Jackson
Mike Jackson
If this is a compilation error,create a preprocess file and submit a bug to https://premier.intel.com
The support team should be able to help you.
I downloaded VTK-5.0.4 and cmake-2.4.8 and built VTK with Intel Compiler for Mac OS X 10.1.014.
I didn't see any errors. I was not able to find VTKvarient.cxx though.
Couple things. First, thanks for taking the time to try this out. Next, I haven't tried the latest icc 10.1.014 yet so that might make a difference. Also, I think you will need to check out the latest VTK from their cvs server and try to compile that.
Note that when you run cmake (if you are NOT familiar with cmake) to set the CMAKE_BUILD_TYPE to "Release". The compile works in "Debug" mode.
Mike Jackson
Mike Jackson
I am behind a firewall, so I can't check out stuff. The lastest source release that I can download from www.vtk.org is version 5.0.4.
I am not familiar with cmake. I'll take a look again if you can provide all the steps neccessary with cmake to reproduce the problem.
It would be easiest if you can preprocessed the file vtkVarient.cxx and attached it here with the command line options to reproduce the problem.
