Dear Sir/Madam,
I am getting the following error message when I try to load c++ executable for the intel debugger (idb). (I am using template based c++ code for my work)
Warning: bad source correlation found. Further instances ignored.)
I would really appreciate if you could kindly let me know how to rectify this error please.
Best Regards
Malin
You're welcome.
The problem isn't specific to templates and there are no known workarounds for the underlying issue of the errent compiler debug emissions.
However, if you're experiencing related problems with debugging, I can probably suggest workarounds specific to those problems.
In your particular case, unless you're attempting to debug the library code itself at the source level, you shouldn't experience anything anomalous.
-- G
