I have successfully build LLVM and clang with ICC, but cannot build llvm-gcc. This is the error.
../../trunk/gcc/llvm-types.cpp(832): error: "Ty", declared in condition, may not be redeclared in this scope
const Type *Ty;
Let me try building ths with the latest 11.1 and see if I can reproduce the problem. I'll let you know right after, appreciate much.
-regards,
Kittur
Could you attach the system info and the gcc info etc., that you used to build this? Also could you please try with the latest 11.1 compiler as we couldn't reproduce the problem, thanks.
-regards,
Kittur
-regards,
Kittur
I have already deleted the svn directory, but will try again at some point and report back then.
Topic Options
