Intel® C++ Compiler
7956 Discussions
Error compiling llvm-gcc with ICC 11.1 in Linux
tp5
I have successfully build LLVM and clang with ICC, but cannot build llvm-gcc. This is the error.
../../trunk/gcc/llvm-types.cpp(832): error: "Ty", declared in condition, may not be redeclared in this scope
const Type *Ty;
KitturGanesh
Let me try building ths with the latest 11.1 and see if I can reproduce the problem. I'll let you know right after, appreciate much.
-regards,
Kittur
KitturGanesh
Could you attach the system info and the gcc info etc., that you used to build this? Also could you please try with the latest 11.1 compiler as we couldn't reproduce the problem, thanks.
-regards,
Kittur
tp5
I have already deleted the svn directory, but will try again at some point and report back then.
