I'm trying to write a simple template function that takes two floating-point values x and y as arguments and returns fmod(x, y):
#include
#include
template
T foo(T x, T y) {
return fmod(x, y);
int main(int argc, char* argv[]) {
float x = 4.0, y = 1.0;
double a = 3.5, b = 9.2;
std::cout << "foo(" << x << ", " << y << ") = " << foo
std::cout << "foo(" << a << ", " << b << ") = " << foo
When I try to compile, I get a number of errors like:
1>.\main.cpp(14): error: expected an expression
1> return fmod(x, y);
1> ^
1> detected during instantiation of "T foo(T, T) [with T=float]" at line 21
Any ideas what this error message means? Thanks.
#include
#include
template
T foo(T x, T y) {
return fmod(x, y);
1>.main.cpp(14): error: expected an expression
1> ^
I tried switching #include
So my next question is, how can I use the functionality from
Also, in
C99 doesn't understand C++ syntax, such as any usage of
ICL doesn't do much in the way of adding functions, it simply uses those provided by VC, so you don't get library support when you set /Qlong-double in ICL.
the same for copysign
http://msdn.microsoft.com/en-us/library/aa246720.aspx
#include
#include
Wow you're right, I can't believe I missed that...however, I also need erf(), which MSVC doesn't seem to provide (I hope I'm right about this one, I actually checked this time). Which leaves me with the same issue as before. Tim's answer clarified why I can't use
catastrophic error: #error directive: "
Agreed, the documentation is confusing on this point. Apparently,
ICL links againstits ownlibm.h; the long double functions are hidden (replaced by double) unless we set /Qlong-double /Qpc80 and use
As the doc on Qlong-double says, there is no printf support for 80-bit long double in any Intel or Microsoft Windows library.
