Intel® C++ Compiler
Error in setting up the compiler environment
Gheibi__Sanaz
For months I have been using intel C++ compiler and each time I have used the same command "source /opt/intel/bin/compilervars.sh intel64" and it has gone through successfully. Just today, I used that same command for setting up the compiler environment and this time, there was an error that "-bash: child setpgid (127014 to 126952): No such process". I don't know what has gone wrong this time. I will really appreciate your help with that.
Best,
Sanaz
Viet_H_Intel
May be try to reboot the machine to see if it helps?
Viet
Viet_H_Intel
Viet
Gheibi__Sanaz
Thank you very much Viet. It helped, but do you know what could have been the cause for that?
Best,
Sanaz
