I am getting this error :-
(0): internal error: 0_45589
when compiling a C++ file with the -g flag. Without the -g flag compilation goes through fine. This is using icc 8.0 on RHEL 3.0 :-
$icc -V
Intel C++ Compiler for 32-bit applications, Version 8.0 Build 20040304Z Package ID: l_cc_pc_8.0.058_pe061
Copyright (C) 1985-2004 Intel Corporation. All rights reserved.
$icc -V
Here are some suggestions:
1. Try a newer version of the 8.0 compiler.
2. Consider moving to 8.1
3. If neither of these work, file a premier support issue.
4. Turn off -g for the file that causes the compiler to crash
Hopefully, one of these will work for you.
Max
Topic Options
