Intel® C++ Compiler
7783 Discussions
Error :: register may not be specified as both modified and preserved
Naveen_Tulabandula
Hi
I am trying to write code which uses intrinsics like
__cpuid(cpuinfo, 1);
and
xcr = _xgetbv(_XCR_XFEATURE_ENABLED_MASK);
The code is compiling fine on win64
But i am seeing below error message in win32
"catastrophic error: register may not be specified as both modified and preserved in #pragma
 linkage"
The compilation is going fine with microsoft CL compiler.
Let me know when we see such error message.
I am unable to reproduce this in a standalone testcase
I am using icl 12.0.5.227
Georg_Z_Intel
newer 12.1 versions (Intel® Composer XE 2011 Update 6 and higher) don't show this problem anymore.
I'm currently clarifying with engineering which exact version has fixed this problem.
Edit: Intel® Composer XE 2011 Update 11 is reported to have a fix for that.
Would it be possible for you to upgrade to the latest version: Intel® Composer XE 2011 Update 11?
Thank you & best regards,
Georg Zitzlsberger
