Dear All,
I tried to compile my C code using Eclipse with Intel C/C++ compiler 13.1.1 on scientific linux 6.4 x64 platform. When linked dynamically, it was successful with no error or warnings. When linked with -static and -L/usr/lib/x86_64-redhat-linux5E/lib64/, it reported many error about undefined reference shown as follows:
make -k all
Building file: ../src/mcmc_demo.c
Invoking: Intel Intel(R) 64 C Compiler
icc -O3 -ip -mkl=parallel -openmp -MMD -MP -MF"src/mcmc_demo.d" -MT"src/mcmc_demo.d" -c -o "src/mcmc_demo.o" "../src/mcmc_demo.c"
Finished building: ../src/mcmc_demo.c
Building target: mcmc_demo
Invoking: Intel Intel(R) 64 C Linker
icc -static -openmp -mkl=parallel -O3 -L/usr/lib/x86_64-redhat-linux5E/lib64/ -o "mcmc_demo" ./src/mcmc_demo.o
./src/mcmc_demo.o: In function `main':
../src/mcmc_demo.c:(.text+0x71): undefined reference to `__isoc99_fscanf'
../src/mcmc_demo.c:(.text+0x100): undefined reference to `__isoc99_fscanf'
../src/mcmc_demo.c:(.text+0x174): undefined reference to `__isoc99_fscanf'
../src/mcmc_demo.c:(.text+0x230): undefined reference to `__isoc99_fscanf'
../src/mcmc_demo.c:(.text+0x43a): undefined reference to `__isoc99_fscanf'
../src/mcmc_demo.c:(.text+0x5ed): undefined reference to `vdLn'
../src/mcmc_demo.c:(.text+0xd00): undefined reference to `vslNewStream'
../src/mcmc_demo.c:(.text+0xd28): undefined reference to `vdRngUniform'
../src/mcmc_demo.c:(.text+0xd42): undefined reference to `vdLn'
../src/mcmc_demo.c:(.text+0xe15): undefined reference to `vdRngGaussian'
../src/mcmc_demo.c:(.text+0xeac): undefined reference to `vdLn'
../src/mcmc_demo.c:(.text+0x1561): undefined reference to `cblas_dcopy'
../src/mcmc_demo.c:(.text+0x159f): undefined reference to `cblas_dcopy'
../src/mcmc_demo.c:(.text+0x1607): undefined reference to `cblas_dcopy'
../src/mcmc_demo.c:(.text+0x1645): undefined reference to `cblas_dcopy'
../src/mcmc_demo.c:(.text+0x16b1): undefined reference to `cblas_dcopy'
../src/mcmc_demo.c:(.text+0x175f): undefined reference to `vslDeleteStream'
./src/mcmc_demo.o: In function `asm2d':
../src/mcmc_demo.c:(.text+0x8184): undefined reference to `cblas_dgemv'
./src/mcmc_demo.o: In function `logpriorfun':
../src/mcmc_demo.c:(.text+0x81c3): undefined reference to `vdLn'
./src/mcmc_demo.o: In function `proprnd':
../src/mcmc_demo.c:(.text+0x8470): undefined reference to `vdRngGaussian'
make: *** [mcmc_demo] Error 1
make: Target `all' not remade because of errors.
Does anyone have idea that how to resolve this issue? Thanks in advance.
Lee
Yes, the path to MKL libraries is correct. When linked dynamically (without -static or -static-intel option), it was OK with no error or warnings. These error were only reported while linking statically.
The log shown in my previous post was copied from the Eclipse console output. I also tested it in command line:
[sl@localhost test]$ icc -O3 -ip -mkl=parallel -openmp -static mcmc_demo.c
ld: cannot find -lm
Following the webpage http://software.intel.com/en-us/forums/topic/277227 and http://software.intel.com/en-us/articles/error-ld-cannot-find-lm/, I tested the new compile options:
[sl@localhost test]$ icc -O3 -ip -mkl=parallel -openmp -static mcmc_demo.c -L/usr/lib/x86_64-redhat-linux5E/lib64/
/tmp/iccondg4F.o: In function `main':
/tmp/iccondg4F.o: In function `asm2d':
/tmp/iccondg4F.o: In function `logpriorfun':
/tmp/iccondg4F.o: In function `proprnd':
When using 'icc -O3 -ip -mkl=parallel -openmp mcmc_demo.c', it works fine and built the executalbe 'a.out' without any error. It seem that the issue is related to the function 'fscanf' and static linking to MKL.
Enabling C99 support with the option -std=c99 did not help to resolve the '__isoc99_fscanf' error:
[sl@localhost test]$ icc -O3 -ip -std=c99 -mkl=parallel -openmp -static mcmc_demo.c -L/usr/lib/x86_64-redhat-linux5E/lib64/
/tmp/icct1sV8V.o: In function `main':
Following the advice by Ying (http://software.intel.com/en-us/comment/1740145#comment-1740145), explictly linking MKL resolved the error 'undefined reference' to MKL functions.
After several test, I also found that using the option '-L/usr/lib/x86_64-redhat-linux5E/lib64/' leads to undefined reference to `__isoc99_fscanf'. Without this option, it reported 'ld: cannot find -lpthread' instead. Detailed logs are as follows:
[sl@localhost test]$ icc -O3 -ip -openmp -static mcmc_demo.c -Wl,--start-group $MKLROOT/lib/intel64/libmkl_intel_lp64.a $MKLROOT/lib/intel64/libmkl_intel_thread.a $MKLROOT/lib/intel64/libmkl_core.a -Wl,--end-group -lpthread -lm
[sl@localhost test]$ icc -O3 -ip -openmp -static mcmc_demo.c -L/usr/lib/x86_64-redhat-linux5E/lib64/ -Wl,--start-group $MKLROOT/lib/intel64/libmkl_intel_lp64.a $MKLROOT/lib/intel64/libmkl_intel_thread.a $MKLROOT/lib/intel64/libmkl_core.a -Wl,--end-group -lpthread -lm
/tmp/iccZTzhHD.o: In function `main':
Yes, I also reported the issue to MKL forum to resolve the issue on static linking MKL. I am sorry for my duplicate posts. Thank you very much for your help, Sergey.
