Intel® C++ Compiler
7956 Discussions
Errors with boost::log compilation on Linux
kwilk
I am trying to compile Boost 1.40 with log library and icpc (v. 11.1 20090630) fails with the following error (among others that follow):
../../../libs/log/src/attribute_set.cpp(415): error: no operator "!=" matches these operands
operand types are: boost::log_st::basic_attribute_set::iter<'\000'> != boost::log_st::basic_attribute_set::iter<'\000'>
while (begin != end)
detected during instantiation
The same code compiles successfully on WinXP and with GCC (4.3.3) on the same linux machine.
You can find system information, OS specific bjam command line and logs of unsuccessful compilation of boost related to this problem in the attached files.
Could you advise on what to do to fix this issue?
TimP
It looks like a g++ template compatibility problem. Maybe an earlier version of g++ and/or a later version of icpc could help. I'm not volunteering to compare pre-processed source files, particularly if you're not.
Brandon_H_Intel
Quoting - tim18
We believe we have a fix for this that we're working on validating now. I'll update the thread when a compiler package with the fix is available.
Brandon_H_Intel
This compiler error has now been fixed in the 11.1.059 compiler now available.
