In order to capture exception messages (from the what() method) and make sure that exceptions are not thrown past parallel OpenMP sections, the following pattern is used.
When testing the attached code using OpenMP paralellisation with the pattern, it seems to work fine all the time.
But when this pattern is run in a bigger application, it segfaults pretty much all the time:
bool abort = false; // shared variable that indicates an abort
string error_message; // shared variable that should contain the exception messages
#ifdef _OPENMP
#pragma omp parallel for collapse(2) schedule(dynamic)
#endif
for (int xl = m_area.second.m_begin; xl < m_area.second.m_end; xl += m_area.second.m_stride) {
for (int sl = m_area.first.m_begin; sl < m_area.first.m_end; sl += m_area.first.m_stride) {
#ifdef _OPENMP
#pragma omp flush (abort)
#endif
if (!abort) {
try {
throw std::runtime_error("Throwing some exception!"); // <-- this is usually a bigger mess which can throw
} // if !abort
catch (exception const & e) {
#ifdef _OPENMP
#pragma omp critical (VEL_ERROR_MESSAGE_WRITE)
#endif
error_message += string(e.what()) + string("\n"); // <-- this is where the segmentation violation happens
abort = true;
#ifdef _OPENMP
#endif
catch (...) {
#ifdef _OPENMP
#endif
error_message = "Unknown exception!";
abort = true;
#ifdef _OPENMP
#endif
} // if (!abort)
} // end of sl loop
} // end of xl loop
#ifdef _OPENMP
#pragma omp barrier
#endif
if (abort) {
throw runtime_error("Velocity precomputation encountered"
" the following error: " + error_message);
If the bigger application is run in a debugger, the debugger reports a segmentation violation when assigning the exception string to the shared variable in the critical section. The stack trace is as follows: __kmp_release_lock <- __kmpc_end_critical <- ...537__par_loop0_2_1460 <-...
Is the pattern itself flawed?
Any advice or help on how to resolve the problem would be very much appreciated!
Best regards
Andreas
Sergey,
The lexical_cast is not an essential part of the testing or the original program. This can be removed. I just thought it nicer to have a report on which thread is throwing.
The command line options for the debug build are:
icpc -static -g -traceback -w -vec_report3 -DMKL -DIPP -DOMP -D__PURE_INTEL_C99_HEADERS__ -openmp -O0 -fp-model precise -o exception2 exception2.cc
This is to stay in line with the original applications command line options. But as mentioned in the original post, I never saw the test exception2.cc code having the same issue as the big application.
Best regards
Andreas
Sergey,
I have tried setting OMP_STACKSIZE and KMP_STACKSIZE, but I still get the segmentation violation. In addition, sometimes I get similar messages to:
*** glibc detected *** bin/Linux/2.6/x86_64_SSE4_c6/application: double free or corruption (!prev): 0x00007ffb28083ee0 ***
Sometimes it is more than just this line.
Should I also try to increase the normal program stack size?
Thank you very much for your help!
Best regards
Andreas
Try:
[cpp]
#ifdef _OPENMP
{ // *** add this
#endif
abort = true;
#ifdef _OPENMP
} // *** add this
#endif
[/cpp]
Jim Dempsey
Do the same for the catch(...) critical section.
Jim Dempsey
Jim,
Unfortunately adding the brackets does not help.
Sergey,
Could you explain the difference between stack reserve and stack commit size? I am running those tests on a Linux system and I only know about a generic stack size.
Thank you very much for all your help!
Best regards
Andreas
As you're not interested in Windows, you can ignore the reserve/commit stuff and read up on how the shell of your choice sets stack limit.
Sergey,
I have now tried increasing the stack size (both OpenMP and the process limit) by setting OMP_STACKSIZE 16m and limit -s unlimited.
This does not help. The application still segfaults at this point.
I am also not sure if this is related to the stack size, as I can see no recursive calls here and I do not think that I have big objects on the stack. The machine I am running this on a 16 core machine, but an 8 core machine shows the same behaviour.
I have also tried the printf instead of the std::string operation. This does not help either. The exception message is printed to the console several times, but then the segfault happens. ( SIGSEGV Segmentation Violation signal)
And I also tried compiling with the above stack related compiler options. No luck with that either.
Best regards
Andreas
If I run the application in gdb, I get the following output (not sure if this is useful though):
[New Thread 0x2aab60d3a700 (LWP 28544)]
[New Thread 0x2aab61778700 (LWP 28545)]
[New Thread 0x2aab6c400700 (LWP 28546)]
[New Thread 0x2aab6c801700 (LWP 28547)]
[New Thread 0x2aab6cc02700 (LWP 28548)]
[New Thread 0x2aab7c400700 (LWP 28549)]
[New Thread 0x2aab84801700 (LWP 28550)]
[New Thread 0x2aab84c02700 (LWP 28551)]
[New Thread 0x2aab90400700 (LWP 28552)]
[New Thread 0x2aab90801700 (LWP 28553)]
[New Thread 0x2aab9c400700 (LWP 28554)]
[New Thread 0x2aab9c801700 (LWP 28555)]
[New Thread 0x2aaba8400700 (LWP 28556)]
[New Thread 0x2aaba8801700 (LWP 28557)]
[New Thread 0x2aabb4400700 (LWP 28558)]
[New Thread 0x2aabb4801700 (LWP 28559)]
Program received signal SIGSEGV, Segmentation fault.
0x000000000125186a in __kmp_acquire_lock ()
and
(gdb) backtrace
#0 0x000000000125186a in __kmp_acquire_lock ()
#1 0x000000000123bca4 in __kmpc_critical ().
The two likely causes of this are:
a) Code in __kmp_acquire_lock () pushed something over the edge of available stack.
b) The pointer to the lock variable is in never never land (address not mapped to your process's virtual memory)
As to what instigates these conditions... you've got the code.
Jim Dempsey
Does icpc have an analog to ifort's -heap-arrays option? That option in the fortran compiler lets you set a threshold at which the compiler will allocate certain arrays on the heap vs the stack and has solved problems with openmp and segfaults for me in the past.
Sergey Kostrov wrote:
>>...Does icpc have an analog to ifort's -heap-arrays option?
No and it is a known issue ( discussed a couple of times ) that some number after -heap-arrays option ( like -heap-arrays 1024 ) is ignored.
That ifort allocation size option allows only fixed size allocations (size known at compile time) to go on heap. More useful might be an option which puts small fixed size allocation on stack and larger ones on heap.
Without the numeric option, the current ifort heap-arrays option puts all allocations on heap. I suppose Sergey meant that when you give a numeric option, it leaves all variable size allocations on stack.
The programmer can change:
double foo[someBigSize];
to
vector<double> foo(someBigSize);
For those stack allocations that are exceedingly large
Jim Dempsey
I did not have too much time to look more closely into debugging this issue. One thing I tried (successfully) is to use an array of strings (std::vector< std::string >) to collect the exception messages. The vector itself is a global array and has one element for each thread. Using the omp_get_thread_num function, the catch part then assigns the exception message from what() to the thread's element in the string vector. That seems to work.
Regarding the elements on the stack, I am already using dynamic (heap) allocation of pretty much all data. At least in the parts of the code that I have immediate control over. I will check if there could be problem with that.
Jim: Is there any way to see if the stack gets corrupted in the loop? Any tool that might help?
Best regards
Andreas
