I have compiled the OpenCV release 2.3 with the Intel C++ Compiler XE 12.0 without problems but when I run use opencv_imgproc.dll (e.g. with the test program opencv_test_imgproc.exe) I get an error in the following piece of code (filter.cpp line 2696):
intrtype=getKernelType(_rowKernel,
_rowKernel.rows==1?Point(_anchor.x,0):Point(0,_anchor.x));
The same code runs with no errors if compiled with Microsoft's compiler (Visual Studio 2010) and the following code runs also with both compilers:Unbehandelte Ausnahme bei 0x0f83ebb4 (opencv_imgproc230d.dll) in opencv_test_imgprocd.exe: 0xC0000005: Zugriffsverletzung beim Schreiben an Position 0xcccccccc.ecx=0CCCCCCCCh (sorry for the German text, it is anaccess violation at ...)
intrtype; if(_rowKernel.rows==1) rtype=getKernelType(_rowKernel,Point(_anchor.x,0)); else rtype=getKernelType(_rowKernel,Point(0,_anchor.x));
If I change this code it will crash at similar code pieces, so I have to change (and check) a lot of code. Is there any compiler switch I have to change?
Any idea is appreciated.
Best regards
Dieter
could you post your compile/link options here?
Or the build log files for the dll and the .exe.
thanks,
Jennifer
Here are the compiler settings:
/I"C:/Program Files/Intel/ComposerXE-2011/tbb/include" /I"C:/Program Files/Intel/ComposerXE-2011/ipp/include" /I"C:/OpenCV2.3/opencv/." /I"C:/OpenCV2.3" /I"C:/OpenCV2.3/opencv/include" /I"C:/OpenCV2.3/opencv/include/opencv" /I"C:/OpenCV2.3/opencv/modules/imgproc/include" /I"C:/OpenCV2.3/opencv/modules/imgproc/src" /I"C:/OpenCV2.3/modules/imgproc" /I"C:/OpenCV2.3/opencv/modules/imgproc/../core/include" /I"C:/OpenCV2.3/opencv/modules/imgproc/test" /I"C:/OpenCV2.3/opencv/modules/imgproc/../imgproc/include" /I"C:/OpenCV2.3/opencv/modules/imgproc/../ts/include" /I"C:/OpenCV2.3/opencv/modules/imgproc/../highgui/include" /Zi /nologo /W4 /O2 /Ob2 /Oi /Qparallel /Quse-intel-optimized-headers /D "WIN32" /D "_WINDOWS" /D "_CRT_SECURE_NO_DEPRECATE" /D "_CRT_NONSTDC_NO_DEPRECATE" /D "_SCL_SECURE_NO_WARNINGS" /D "NDEBUG" /D "HAVE_IPP" /D "HAVE_CVCONFIG_H" /D "CMAKE_INTDIR="Release"" /D "CVAPI_EXPORTS" /D "_WINDLL" /D "_MBCS" /MD /GS /Gy /arch:SSE2 /fp:precise /Zc:wchar_t /Zc:forScope /GR /Yu"C:/OpenCV2.3/opencv/modules/imgproc/src/precomp.hpp" /Fp"opencv_imgproc.dir\Release\opencv_imgproc230.pch" /Fa"Release" /Fo"opencv_imgproc.dir\Release" /Fd"C:/OpenCV2.3/bin/Release/opencv_imgproc230.pdb" /Gd /TP /FI"C:/OpenCV2.3/opencv/modules/imgproc/src/precomp.hpp"
I have downloaded the source code and just switched from MS Visual C++ to Intel C++.
Dieter
Hi Lorenz
This issue is fixed in Intel C++ Compiler 12.1 Update 7. You can downlad this latest version of C++ compiler from Intel registration center and try building the OpenCV2.3. Please get back to us if you face some issues.
Thanks and Regards
Anoop
Topic Options
