Expression can Not be evaluated in Watch or Quick Watch Windows of a Visual Studio if there is at least one space before or after template data type. The following UI error is displayed:
CXX0019: Error: bad type cast
More technical details will be provided. Thanks.
Sergey Kostrov wrote:
I think the problem is related to some UI issue of VS however investigation is needed to confirm that it is Not related to Intel or Microsoft C++ compilers.
Have you tried reproducing this with a project that uses the MSVC compiler? That would seem to be prudent when posting a bug that strongly looks like (and you acknowledge might be) an issue with VS.
which version of icl are you using? I tried your testcase, "ConTestApp", both "debug|win32" and "release|win32" build fine.
Jennifer
I saw the issue now.
I don't think it's a compiler issue. It's more like an issue in the Visual C++'s Expression evaluator. Have you check with msdn forum?
Jennifer
