Intel® C++ Compiler
FFTW 3.3.10 configure fails
bjwiley233
OS: MacOS Big Sur
$ icc --version
icc (ICC) 2021.4.0 20210910
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
This is the oneapi icc version...
When I run
./configure CC="icc -no-gcc"
or
./configure CC="icc -gcc-sys"
Checking the C compiler fails with below.  Can you try on Big Sur with latest version here https://www.fftw.org/
configure:4178: checking for gcc
configure:4205: result: icc -no-gcc
configure:4434: checking for C compiler version
configure:4443: icc -no-gcc --version >&5
configure:4454: $? = 0
configure:4443: icc -no-gcc -v >&5
icc version 2021.4.0 (gcc version 4.9.0 compatibility)
configure:4443: icc -no-gcc -V >&5
Intel(R) C Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.4.0 Build 20210910_000000
configure:4443: icc -no-gcc -qversion >&5
icc: command line warning #10006: ignoring unknown option '-qversion'
icc: command line error: no files specified; for help type "icc -help"
configure:4454: $? = 1
configure:4474: checking whether the C compiler works
configure:4496: icc -no-gcc    conftest.c  >&5
ld: library not found for -lc++
configure:4500: $? = 1
configure:4538: result: no
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "fftw"
| #define PACKAGE_TARNAME "fftw"
| #define PACKAGE_VERSION "3.3.10"
| #define PACKAGE_STRING "fftw 3.3.10"
| #define PACKAGE_BUGREPORT "fftw@fftw.org"
| #define PACKAGE_URL ""
| #define PACKAGE "fftw"
| #define VERSION "3.3.10"
| #define FFTW_ENABLE_ALLOCA 1
| /* end confdefs.h.  */
| int
| main ()
|   return 0;
configure:4543: error: in `/Users/brian/tools/fftw-3.3.10':
configure:4545: error: C compiler cannot create executables
See `config.log' for more details
VarshaS_Intel
We can see that you are trying to configure FFTW using the option "-no-gcc" or "-gcc-sys", could you please let us know if there is any specific reason for that?
We have tried at our end using the below command and we are able to configure it.
./configure CC="icc" CPPFLAGS=-I/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include DFLAGS=-Qoption,cpp,--gnu_version=40805
Could you please let us know if you are still facing any issues?
Thanks & Regards
Varsha
VarshaS_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Varsha
