Intel® C++ Compiler
7956 Discussions
Fail to integrated ICC 11.0 into VC2005 ide
Wenhao_Z_Intel1
I installed icc 11.0 and VSIntegration. icc works well since i have compiled sample code of IPP with it. But VS integration doesn't work. There's no icon or options to change the compiler. Just like the icc isnot installed..
Could someone can tell me how to do? Thanks!
JenniferJ
You said it works with ipp sample: what do you mean?
Several other things to check:
1. open VS2005, open the Help->About, scroll down the list, do you see Intel C++ Compiler Integration listed?
2. still within VS2005, open Tools -> Options, do you see "Intel C++"?
3. do you see a folder like intelcompilervsintegrationvs2005?what do you have at this folder?
Jennifer
Wenhao_Z_Intel1
Jennifer,
Thank you for the reply.
I run theIPPsample of audio-video-codecs, its compiling script can detect and use the ICC automatically. I think it means icc has been installed in my machine correctly.
no
still no
yes. Its locations is IntelCompiler11.0�61cppCompilerVS IntegrationC++VS2005. In it, there are two folders (1033 and 1041), icUtil.dll, IntelPkg.dll, OptPkg.dll and integrate.bat
JenniferJ
Quoting - questionmark
Ok. This is great. Steps below:
1. Copy/Paste "integrate.bat" to "IDE_install.bat".
2. Edit "IDE_install.bat" with Notepad and remove all the "/s" in the "regsvr32" command line.
3. open a cmd window and run cmd below:
>> IDE_Install "VS2005_Dir"
See what error you get.
If no error, open VS2005 and check if the IntelC toolbar is there.
If error, please post the error msg or image.
Jennifer
Wenhao_Z_Intel1
Thank you. I did as you said and ICC toolbox appeared. But a error message box as follows is encountered now.
Bests,
Wenhao
JenniferJ
This GUID is from "optpkg.dll". when registering it, did you get any error msg?
Please check registry: HKLMsoftwaremicrosoftVisualStudio8.0packages{477A1EE1-A43E-.......}, it should contain following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINESOFTWAREMicrosoftVisualStudio8.0Packages{477A1EE1-A43E-4250-A512-A0DF1F30891E}]
@="Intel C++ Compiler Integration Package, Tool Option"
"InprocServer32"="C:\Program Files\Intel\Parallel Studio\Composer\VS Integration\C++\VS2005\OptPkg.dll"
"CompanyName"="Intel Corporation"
"ProductName"="Intel C++ Compiler Integration Package, Tool Option"
"ProductVersion"="11.1"
"MinEdition"="Standard"
"ID"=dword:00000001
"InstallPath"="C:\Program Files\Intel\Parallel Studio\Composer\VS Integration\C++\VS2005"
[HKEY_LOCAL_MACHINESOFTWAREMicrosoftVisualStudio8.0Packages{477A1EE1-A43E-4250-A512-A0DF1F30891E}Automation]
"IntelOptions"="Intel Options Package Automation"
"PrjConvert"="Project conversions automation"
[HKEY_LOCAL_MACHINESOFTWAREMicrosoftVisualStudio8.0Packages{477A1EE1-A43E-4250-A512-A0DF1F30891E}SatelliteDll]
"DllName"="OptPkgUI.dll"
"Path"="C:\Program Files\Intel\Parallel Studio\Composer\VS Integration\C++\VS2005"
Wenhao_Z_Intel1
All the registerations were succeed and i checked the registry. It also seems to be correct. :(
"InprocServer32"="C:\Program Files\Intel\Compiler\11.0\061\cpp\Compiler\VS Integration\C++\VS2005\OptPkg.dll"
"ProductVersion"="11.0"
"ID"=dword:00000001
"InstallPath"="C:\Program Files\Intel\Compiler\11.0\061\cpp\Compiler\VS Integration\C++\VS2005"
"Path"="C:\Program Files\Intel\Compiler\11.0\061\cpp\Compiler\VS Integration\C++\VS2005"
JenniferJ
Ok.
Do you have this file "C:Program FilesMicrosoft Visual Studio 8SDKv2.0Bingacutil.exe"?
If not, it's needed. There's a posting about modifying the VS2005 to install it.
If yes, we need to try more:
1. download the latest 11.0.074
2. from Add/Remove, remove 11.0.61 including the IDE integration.
If the IDE integration does not show up on the Add/Remove, use the following cmd:
>> cd "C:Program FilesIntelCompiler11.0�61cppCompilerVS IntegrationC++VS2005"
>> uninstall_vc8.bat
>> uninstall_vc8.bat
>> uninstall_vc8.bat
(3 times uninstalling)
3. install the 11.0.074.
(install_vc8.bat & uninstall_vc8.bat attached.)
Jennifer
Wenhao_Z_Intel1
I tried the latest version of ICC, the same error remained. And i also tried to re-install my vc8, still with no result.
It's so disappointing...
Anyhow, thanks a lot for your patient help.
JenniferJ
Please check this known-issue -http://software.intel.com/en-us/articles/intel-c-compiler-for-windows-the-ide-integration-does-not-work-within-visual-studio-2005/
Jennifer
JenniferJ
Please checking this posting as well http://software.intel.com/en-us/forums/showthread.php?t=57659
Jennifer
