Intel® C++ Compiler
7957 Discussions
Failed to compile the MIT amalgamated gcc.c into a x86 ELF binary (internal error: 04010022_1238)
Kaiyuan
The source code is at https://people.csail.mit.edu/smcc/projects/single-file-programs/gcc.c.bz2
The icc version I used was v19.1.1.219
The command I used was: "icc gcc.c -O2 -m32 --save-temps -g -Wno-error -lm -o gcc"
The compilation failed because of: "gcc.c(660840) (col. 1): internal error: 04010022_1238"
I have tried targeting x64 ELF, and it did not have this problem.
By using "-O0" and "-O1" instead of -O2 for x86, the compilation did succeed.
The compilation was run under a clean x64 ubuntu 20.04 docker container with only intel-sw-tools and its dependencies installed. The host machine has 128G RAM.
GouthamK_Intel
Thanks for providing the suggestion and required details!
We are able to reproduce the issue on our end.
We are forwarding your issue to the concerned team.
Thanks & Regards
Goutham
GouthamK_Intel
Thanks for reaching out to us!
We tried to reproduce the issue on Ubuntu 18.04, we are getting the following errors.
$ icc gcc.c -O2 -m32 --save-temps -g -Wno-error -lm -o gcc
gcc.c(50400): warning #47: incompatible redefinition of macro "__NO_STRING_INLINES"
 #define __NO_STRING_INLINES
In file included from /usr/include/features.h(448),
         from /usr/include/libintl.h(23),
         from gcc.c(1524):
/usr/include/x86_64-linux-gnu/gnu/stubs.h(7): catastrophic error: cannot open source file "gnu/stubs-32.h"
 # include <gnu/stubs-32.h>
compilation aborted for gcc.c (code 4)
However, we will test it on Ubuntu 20.04.
We working on your issue at our end, we will get back to you soon.
Thanks & Regards
Goutham
Kaiyuan
It seems to me that the x86 version of libc is missing. Did you install "libc6-dev-i386" and "g++-multilib" in your system?
I have also posted the compiler installation part of the Dockerfile I used to for my investigation. Hope it can help you regenerate this error.
GouthamK_Intel
Thanks & Regards
Goutham
Viet_H_Intel
I've reported this bug to our Developer. Thanks,
Viet_H_Intel
Our developer has decided not to fix this bug. Hence I am going to close this thread.
