The source code is at https://people.csail.mit.edu/smcc/projects/single-file-programs/gcc.c.bz2
The icc version I used was v19.1.1.219
The command I used was: "icc gcc.c -O2 -m32 --save-temps -g -Wno-error -lm -o gcc"
The compilation failed because of: "gcc.c(660840) (col. 1): internal error: 04010022_1238"
I have tried targeting x64 ELF, and it did not have this problem.
By using "-O0" and "-O1" instead of -O2 for x86, the compilation did succeed.
The compilation was run under a clean x64 ubuntu 20.04 docker container with only intel-sw-tools and its dependencies installed. The host machine has 128G RAM.
Thanks for providing the suggestion and required details!
We are able to reproduce the issue on our end.
We are forwarding your issue to the concerned team.
Thanks & Regards
Goutham
Thanks for reaching out to us!
We tried to reproduce the issue on Ubuntu 18.04, we are getting the following errors.
$ icc gcc.c -O2 -m32 --save-temps -g -Wno-error -lm -o gcc
gcc.c(50400): warning #47: incompatible redefinition of macro "__NO_STRING_INLINES"
#define __NO_STRING_INLINES
In file included from /usr/include/features.h(448),
from /usr/include/libintl.h(23),
from gcc.c(1524):
/usr/include/x86_64-linux-gnu/gnu/stubs.h(7): catastrophic error: cannot open source file "gnu/stubs-32.h"
# include <gnu/stubs-32.h>
compilation aborted for gcc.c (code 4)
However, we will test it on Ubuntu 20.04.
We working on your issue at our end, we will get back to you soon.
Thanks & Regards
Goutham
It seems to me that the x86 version of libc is missing. Did you install "libc6-dev-i386" and "g++-multilib" in your system?
I have also posted the compiler installation part of the Dockerfile I used to for my investigation. Hope it can help you regenerate this error.
Thanks & Regards
Goutham
I've reported this bug to our Developer. Thanks,
Our developer has decided not to fix this bug. Hence I am going to close this thread.
