Intel® C++ Compiler
Failed to install in Windows 7
alienskinsoftware
I have a new Windows 7 system (64-bit) and I'm trying to install icc version 11.1.038 (w_cproc_p_11.1.038.exe) on it. Soon after running the installer, the dialog shows a message about "Reading existing licenses..." and then it seems to hang.
A chklic.exe process can be seen running and using up lots of CPU cycles, but nothing seems to happening.
Does anyone know what's wrong?
TimP
Similar issue:?
http://software.intel.com/en-us/forums/showthread.php?t=68393
Yang_W_Intel
Thanks for reporting. I'll investigate the issue and let you know if there any updates.
alienskinsoftware
Tim, the problem description in the other thread sounds very similar to the problem I'm encountering with icc.
Yang Wang, thanks.
alienskinsoftware
Version 11.1.046 fixes the problem I reported. Thank you.
