Hi All,
I have posted this question to the Parallel Studio forum, seems like this forum is more suitable for this sort of issues.
I've just upgraded 2011 XE to 2013 XE (update 3), one of my projects that intel compiler from 2011 XE package was able to assemble flawlessly fails to compile with ICC 13.x.
An error occurs on the nvcc compilation stage (compiling .cu file with CUDA kernel): nvcc : fatal error : A single input file is required for a non-link phase when an outputfile is specified.
Once again, both MSVC and 2011 XE do compile the project without errors. How to make 13.x do the same thing ?
Many thanks in advance.
For some reason, this topic has appeared almost two days after I've submitted it, this issue is already under discussion in the "CUDA support, any news ?" topic.
Romant, I never was able to compile CUDA code with Intel C++ ! I will try to find my old Intel 2011 and make a test. So, if there was support in the past ... so, what happen ?
It is possible that it was pre-2011 version that compiled projects with .cu files well, I don't remember with sure. Well, that previous version have just invoked nvcc successfully, compiled the rest of h/cpp files and linked all the stuff together, that's all.
Sergey,
I have posted some details in the following branch of this forum: http://software.intel.com/en-us/forums/topic/392250
Jennifer J. from Intel is currently kindly looking into this issue. I have provided her with project files, custom build rules, build log and some other files, can send this info to you as well.
Sent via personal message.
Everything is correct:
--compile -o "x64\Unicode Release Intel/MulticoreHelpers.cu.obj" MulticoreHelpers.cu
First parm in the quotes is the destination path, second one is the file itself. Everything is compiled well with exactly same parameters when compiling via MSVC.
OK, understood. I will try to create a complete reproducer and provide you with it.
Sergey,
Jennifer J. from Intel has finally nailed this issue down. Here is the part of the command line:
nvcc.exe ... "x64\Unicode Release Intel/MulticoreHelpers.cu.obj" "MulticoreHelpers.cu" [AdditionalOptions]
[AdditionalOptions] must have been substituted with actual string from compiler setup, however, for some reason, [AdditionalOptions] substring has been inserted as is. This substring is considered as a filename by nvcc, that is the cause of error.
Waiting for the workaround.
I am interested if this has been resolved and what the workaround it. Last message is from nearly a year ago. Any update?
ok official does Intel not support NVIDIA's CUDA SDK Syntax with the Intel Compilers , but you can use the Intel Compilers
with NVIDIA CUDA SDK, actual i have install on openSUSE 13.2 Milestone 0 (64 Bit) Linux the new NVIDIA CUDA SDK 6.0
and the Intel Cluster STUDIO XE 2015 Beta with the ICC/ICPC Version
icc (ICC) 15.0.0 20140318
Copyright (C) 1985-2014 Intel Corporation. All rights reserved.
icpc (ICC) 15.0.0 20140318
so with a little modification of the host_config.h change from icc != 1310 to icc > 1500 you use the icpc / icc with the CUDA SDK.
i have compile the bandwithtest, matrixMul, matrixMulCUBLAS, particles, nbody and smokeParticles samples from the NVIDIA 6.0 SDK
without any troubles command: make GCC=icpc EXTRA_NVCCFLAGS=-use_fast_math , the executables works correct on my GeForce GTX560 Ti dual SLI Config.
So far this are the steps for Linux i don't know whats gone in a windows environment, i never use it.
regards
Franz
@bernaske
That is interesting.
I will try to do it on Windows platform.
