The included example compiles (and runs) in GCC 5.1, but ICC fails with the following internal error:
assertion failed at: "shared/cfe/edgcpfe/il.c", line 18463
#include "stdafx.h" #include <utility> #include <array> #include <iostream> template <size_t... I, size_t... J> constexpr std::array<char, sizeof...(I) + sizeof...(J) + 1> constcat_impl( const char (&s)[sizeof...(I) + 1], const char (&t)[sizeof...(J) + 1], std::index_sequence<I...>, std::index_sequence<J...>) { return{ s..., t..., '\0' }; } template <size_t M, size_t N, typename I = std::make_index_sequence<M - 1>, typename J = std::make_index_sequence<N - 1>> constexpr std::array<char, M + N - 1> constcat(const char (&s) , const char (&t) ) { return constcat_impl(s, t, I(), J()); } int main() { auto a = constcat("Hello, ", "world!"); std::cout << a.data() << std::endl; return 0; }
Thanks for reporting this issue. I can reproduce this problem and have escalated to compiler engineering.
Anoop
This issue is fixed in 17.0 compiler which is available at Intel Registration Center.
Thanks and Regards
Anoop
