Community
cancel
Showing results for
Search instead for
Did you mean:
coolhelix
Fatal compilation error: Out of memory
Hi, guys,
When I build a project (Release|Win32) with Intel C++ compiler in VS 2008, at the link phase, it reports
6>Linking... (Intel C++ Environment)
6>Fatal compilation error: Out of memory asking for 2097160.
6>xilink: error #10014: problem during multi-file optimization compilation (code 1)
But debug version compile is fine.
Is there some easy way, which would not impact much code, to avoid it?
Compiler command line (optimization two, release version )
/c /O2 /Qipo /I "..\.." /I ".." /EHsc /MD /GS /fp:fast /Fo"Release/" /W4 /WX /nologo /Zi
TimP
Black Belt
Did you read the help file section on IPO for Large Programs ? Whether IPO is even suitable for a large program depends entirely on the characteristics of the program.
Evidently, a program becomes "large" sooner on 32-bit Windows, and when /Zi is set. You may have functions which should be built at /O1, but you're asking for guesses only you are in a position to make.
coolhelix
Quoting - tim18
Thanks. I replace IPO with single file optimization, and build is fine now.
