Intel® C++ Compiler
7932 Discussions
Fatal compilation error icx2022.2.0 on windows
Steffen_Gross
Due the deprecation notice for the classic compiler ,I have tried to switch to the icx compiler.
Most of the project are working, but at one I got permanent the following error
1>icx: : error : clang frontend command failed due to signal (use -v to see invocation)
1>Intel(R) oneAPI DPC++/C++ Compiler 2022.2.0 (2022.2.0.20220730)
Don't know where to put the bugreport, so I have doing this here. As attachment the proprocessed sources as requiered from the compiler output.
Kind regards
Steffen
PriyanshuK_Intel
Thank you for posting on Intel Communities.
Could you please provide us with the below details to investigate more on your issue?
 1. The OS version.
 2. Visual studio version, If you are using it.
 3. Steps to reproduce the issue.
Priyanshu.
Steffen_Gross
- Windows 10 21H2 Build 19044.2075
- Visual Studio 2022 Version 17.3.5
- Build the debug version of the library (release build not tested), only at this library icx is crashing, other libraries and dll's from the same main project are not affectet
crash reproducer in the attachment in the first message.
Kind regards
Steffen
PriyanshuK_Intel
We were able to reproduce your issue from our side. We have informed the development team about it.
We will get back to you soon regarding your issue.
Priyanshu.
NoorjahanSk_Intel
Thanks for your patience.
The backend crash is unexpected, but a compile fail is expected for the source code
Please change the source code by moving alloca() into WinEH blocks.
Please refer to the below link for more details:
https://github.com/llvm/llvm-project/issues/60914
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
Steffen_Gross
I have changed the functions with alloca() some month ago, so the error doesn't occur longer .
Issue can closed.
Regards Steffen
NoorjahanSk_Intel
Thanks for your confirmation.
As this issue has been resolved, we will no longer respond to this thread. If you need any additional information, please post a new question
Thanks & Regards,
Noorjahan.
