Intel® C++ Compiler
7956 Discussions
Feedback 01: Intel(R) C++ Composer XE 2011 - Inconsistent naming
SergeyKostrov
Valued Contributor II
After using Intel C++ Composer XE 2011 Update 9 for some time I'd like to provide a feedback.
I hope that my feedback will help to solve some problems related to naming Intel software products.
Please take a look at different names of the same software product:
[ Visual Studio 2005 ] -> When a Visual Studio 2005 starts ( in a splash dialog box )
[ Visual Studio 2005 ] -> In 'About Microsoft Visual Studio' dialog box of the Visual Studio 2005
Integration for Microsoft Visual Studio* 2005,
Version 12.1.1109.2005, Copyright 2002-2012 Intel Corporation
[ Visual Studio 2005 ] -> Tools -> Options -> Intel C++ -> Compilers:
Intel C++ Compiler XE on IA-32, version 12.1.3 Package ID: w_ccompxe_2011.9.300
[ Visual Studio 2005 ] -> < Some ICC converted project > -> < Right Click > ->
Intel C++ Composer XE 2011 -> Select Build Components:
< Edit Box > Default Suite version:
Intel Composer XE 2011 Update 9 Build 300
[ Visual Studio 2005 ] -> < Build for ICC converted project > ->
Intel C++ Compiler XE 12.1.3.300 [IA-32]
[ Html Docs ] ->
Intel{R} C++ Compiler XE 12.1 Documentation
Intel C++ Compiler XE 12.1 User and Reference Guides
[ Install folders ] -> ..\\"Composer XE" & ..\\"Composer XE 2011 SP1"
[ icl.exe ] -> Properties -> Version ->
File version: 12.1.0.3
Description: Intel C/C++ Compiler
Other version information ->
File version: 12.1.3
Product version: 12.1.3
[ Windows XP ] -> Start -> Programs -> Intel Parallel Studio XE 2011 ->
Command Prompt: Parallel Studio XE with Intel Compiler XE v12.1 Update 3
Documentation: C++ Compiler XE 12.1 Update 3 Documentation
Getting Started Tutorials: C++ Compiler XE 12.1 Update 3 Tutorial
Intel Compiler XE: Using VS2005
Parallel Studio XE 2011 with VS2005 ( shortcut )
[ Windows XP ] -> Start -> Settings -> Control Panel -> Add or Remove Programs:
Intel C++ Composer XE 2011 Update 9 for Windows
Version: 2011.9.300 [EDITED] Changed from '2001' to '2011'
[ Windows Registry ] ->
HKEY_CURRENT_USER\\Software\\Intel\\IDE\\C++\\121
HKEY_CURRENT_USER\\Software\\Intel Corporation\\ComposerXE2011\\12.1.3.300
HKEY_CURRENT_USER\\Software\\Intel Corporation\\ComposerXE2011-OpenMP\\12.1.3.300
HKEY_LOCAL_MACHINE\\SOFTWARE\\Intel\\IDE\\C++\\121
HKEY_LOCAL_MACHINE\\SOFTWARE\\Intel\\IDE\\C++\\Compiler XE 12.1 ->
Display String: Intel C++ Composer XE 2011
ProductVersion: 12.1
Release: Update 9
If you make a master list of all expressions with a key word 'Intel' you will get a list of names:
Intel C++
Intel Compiler XE
and all of the above is for one software product. (!!!)
Another inconsistencies:
Update 9
Update 3
A macro: /D "INTEL_SUITE_VERSION=PE121_300"
Take a look at internal Intel C++ compiler macros
Sergey
Om_S_Intel
Thanks for feedback. I submitted a report to development team on this.
Om
Om_S_Intel
Om
SergeyKostrov
I've done one correction:
dpeterc
I think confusing naming scheme in Intel Composer XE can only be matched by Intel processor names.
Designed by marketing people to remove any information about the actual product and version, content and capabilites.
When I download the product, I see
  • Intel C++ Composer XE for Linux*
  • Version 2011 (Update 10 Eng/Jp) 19 Apr 2012
    The download file is named
    l_ccompxe_2011.10.319.tgz
    And when I check which compiler have I just installed:
    icc --version
    I get a reply:
    icc (ICC) 12.1.4 20120410
    So you changed whole product line names to indicate product release year (did I get this right?), but then release 2011 product in 2012, and then you rename it again, once it is installed?
    SergeyKostrov
    Quoting dpeterc
    Designed by marketing people to remove any information about the actual product and version, content and capabilites...
    These naming inconsistencies did not appear in a couple of days or weeks. It is a clear that this is "accumulated problem" over
    the course of many years!
    Om_S_Intel
    The issue resolved in 16.0.
