Intel® C++ Compiler
FlexRAN20.08 compile issue
sunny_sh2011
We try to build FlexRAN-20.08(5G) by "parallel_studio_xe_2019_update3_cluster_edition", but failed.
There is one error:
error: cannot open source file "ippe.h" as shown below:
nr5g/gnb_ul/gnb_ul_phy_pusch.c(42): catastrophic error: cannot open source file "ippe.h"
#include <ippe.h>
make: *** [l1app] Error 2
 what does this means ? and how should we reslove it ?
Later we try use "system_studio_2020_u1_ultimate_edition_offline" to build FlexRan20.08(5g) and the result is failed.
There are errors as shown in the attaced files.
Please confirm what compiler(ICC) is uesed for FlexRAN-20.08(5G)?
GouthamK_Intel
Thanks for reaching out to us!
We are able to reproduce the error which you are facing, we are escalating your query to the concerned internal team.
Thanks & Regards
Goutham
sunny_sh2011
ok,thanks.
Wait for the response!
Viet_H_Intel
What version of GCC did you use prior to switching to ICC? And let us know which compiler options you had to successfully compile with g++
sunny_sh2011
I have not used other compilers to compile FlexRAN20.08.
When I get FlexRAN software, I follow the intel product documet to do the build works, but it failed as you seen I have met.
Best Regards!
Viet_H_Intel
Seems like there is an issue with System Studio 2020. Can you try the older System Studio version (2019)?
sunny_sh2011
Hi:
1. Where can I get the old version System Studio? It seems I can only get the latest System Studio version from intel site.
2. Can you confirm System Studio(ICC) fits for FlexRAN20.08(5g), and Parallel Studio(ICC) is  not suitable for  FlexRAN20.08(5g)?
Best Regards!
Viet_H_Intel
Can you register your Serial number at https://registrationcenter.intel.com? then you will be able to download older versions.
System Studio is for IoT device applications. So it would fit FlexRan20.08.
sunny_sh2011
We download the free license software now(as shown in the attaced file). We regitstered it by the serial num from the license file, but regitstration failed. How can we get the older version System Studio in such situation
Juhi_B_Intel
Hi Sunny,
I will try to send you the link of the older update through email , let me know if you receive it and reply on the same email if you cannot access the link.
Juhi
sunny_sh2011
I have replied that email, please check.
We need linux version, please give us linux version link.
Thanks!
brightcheng
Hi Juhi
Can you also send me the link to download older update to build FlexRAN? ICC 19.0.3.206
Thanks so much.
Bright
MatheusGarbelini
Hi @Juhi_B_Intel where we can download FlexRAN 20.08? Is it only available through NDA?
Regards.
KaiMiYang
Hi Juhi
Thanks so much.
