Message Edited by tim18 on 08-25-2004 06:08 AM
tcprince,
thank you for the prompt reply. However, I have one observation:
"The -ftz witch only needs to be used on the source containing function main(). The effect of the -ftz switch is to turn on FTZ mode for the process started by main(). The initial thread and anythreads subsequently created by that process will operate in FTZ mode."
According to this, it should be ok if I compile the code containing main(). Am I correct in my understanding ?
regards,
Kalyan
That is correct. If main() is built with -ftz, the abrupt underflow setting persists throughout the application, unless you reset by using the intrinsics or asm code.
The other point about this having no effect on data read from a file is correct as well.
