Hi
I am having a huge application with lots of Fortran files and C files. I am using Intel Compiler Suite Professional Edition for Windows and working in the cygwin environment.
icl is:
Intel C++ Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100806 Package ID: w_cproc_p_11.1.067
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
ifort is:
Intel Visual Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100806 Package ID: w_cprof_p_11.1.067
The C routines are being called from fortran files.
After compiling with intel compilers, Fortran object files have symbols without the trailing underscore while the C files have the object files with the symbols with a trailing underscore.
e.g. C object file has dummy_symbol_
Fortran object file has dummy_symbol
Due to this I am getting unresolved external symbol errors.
This works with other compilers, but with intel compilers, this C and Fortran interoperability issue I am facing.Is there some easy way to fix this, without going into the code and making changes for each routine ?
May be by adding some flag while compiling C/Fortran files or having some environment variable set which can take care of that trailing underscore or some other alternative.. ?
I was looking in the user guide but could not find the reqd. information properly. Can you please let me know how do I resolve this issue ?
Thanks & Regards,
Kunal
