I’ve found a bug in the Intel GLSL compiler on my rMBP2015 under Windows, while working on a new Farbrausch 64k intro for the UnderConstruction 2016 demoparty on the 27th-29th 2016, so the following wrong-running code:
float opSub(const in float d1, const in float d2){ return max(d1, -d2); } .... d = opSub(d, opSub(length(lp.xz) — 2.2, p.y — 6.0)); d = opSub(d, opSub(length(lp.xz — vec2(0.0, -1.6)) — 0.7, p.y — 6.0));
has a different (and wrong) behavior (where opSub will be get a mixed behaviour of opUnion and opIntersection) than this then-right-running code:
#define opSub(d1,d2) max((d1), -(d2)) .... d = opSub(d, opSub(length(lp.xz) — 2.2, p.y — 6.0)); d = opSub(d, opSub(length(lp.xz — vec2(0.0, -1.6)) — 0.7, p.y — 6.0));
and also then-right-running code variant:
float opSub(const in float d1, const in float d2){ return max(d1, -d2); } .... float temp = opSub(length(lp.xz) — 2.2, p.y — 6.0); d = opSub(d, temp); temp = opSub(length(lp.xz — vec2(0.0, -1.6)) — 0.7, p.y — 6.0) d = opSub(d, temp);
So, there seems to be also a bug in the auto-inlining-function-feature and/or register-allocation of the Intel GLSL compiler, I guess.
For see this one issue in action, see my testcase with complete GLSL code at see https://www.youtube.com/watch?v=u0dNKo70X8s and https://gist.github.com/BeRo1985/3a47c5be8b08381edb2d670a13bca606 or here as post file attachment
Regards from Germany,
Benjamin Rosseaux
