Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
7594 Discussions
GNULIB compilation error with Intel 2016.1.150 and 2016.2.181
Balazs_H_
Dear All,
I am trying to use and compile GNUlib libraries using the above mentioned compilers (actually, I am trying to comple Octave, but the problem is related to GNULIB.)
Meanwhile I am able to compile with the 2015 compilers, the 2016 compilers give the following error
make[3]: Entering directory `/tmp/hajgato/build/Octave/4.0.0/intel-2016a/octave-4.0.0/liboctave'
CXX array/array_libarray_la-Array-b.lo
icpc: command line warning #10006: ignoring unknown option '-Wold-style-cast'
icpc: command line warning #10006: ignoring unknown option '-Wcast-align'
In file included from /usr/include/sys/types.h(220),
from ../libgnu/sys/types.h(28),
from /usr/include/stdlib.h(320),
from ../libgnu/stdlib.h(36),
from /vsc/apps/brussel/ivybridge/software/GCCcore/4.9.3/bin/../include/c++/4.9.3/cstdlib(72),
from /vsc/apps/brussel/ivybridge/software/GCCcore/4.9.3/bin/../include/c++/4.9.3/bits/stl_algo.h(59),
from /vsc/apps/brussel/ivybridge/software/GCCcore/4.9.3/bin/../include/c++/4.9.3/algorithm(62),
from array/Array.h(32),
from array/Array-b.cc(29):
../libgnu/sys/select.h(598): error: declaration is incompatible with previous "select" (declared at line 109 of "/usr/include/sys/select.h")
_GL_CXXALIAS_SYS (select, int,
compilation aborted for array/Array-b.cc (code 2)
make[3]: *** [array/array_libarray_la-Array-b.lo] Error 1
make[3]: Leaving directory `/tmp/hajgato/build/Octave/4.0.0/intel-2016a/octave-4.0.0/liboctave'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/tmp/hajgato/build/Octave/4.0.0/intel-2016a/octave-4.0.0/liboctave'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/hajgato/build/Octave/4.0.0/intel-2016a/octave-4.0.0'
make: *** [all] Error 2
 The part of the header files where the problem is (after preporcessing):
./libgnu/sys/select.h:
./libgnu/sys/select.h(599): error: declaration is incompatible with previous "select" (declared at line 109 of "/usr/include/sys/select.h")
namespace gnulib { static int (*select) (int, fd_set *, fd_set *, fd_set *, struct timeval *) = ::select; } extern "C" int _gl_cxxalias_dummy;
compilation aborted for pp.c (code 2)
/usr/include/sys/select.h:
extern "C" {
extern int select (int __nfds, fd_set *__restrict __readfds,
		   fd_set *__restrict __writefds,
		   fd_set *__restrict __exceptfds,
		   struct timeval *__restrict __timeout);
extern int pselect (int __nfds, fd_set *__restrict __readfds,
		    const struct timespec *__restrict __timeout,
		    const __sigset_t *__restrict __sigmask);
(line 109 starts with extern int select .....
Is this a bug in the 2016 version of intel compilers or some standard were more precisely implemented? Again version 2015 compilers do not have this error, the code compiles without any problems.
There is a small testporgram (submitted on the Octave bug forum): http://savannah.gnu.org/bugs/index.php?47373
Melanie_B_Intel
Yes i can reproduce the problem, I opened DPD200408195 in our internal bugs tracking database.
Thank you for reporting this. --Melanie
Hoste__Kenneth
I am also hit by this problem...
Is it confirmed this is a bug in the 2016 versions of the Intel compilers?
If so, is there any workaround available, like using a particular compiler flag, etc.?
Melanie_B_Intel
There's no workaround for the compiler bug.  We expect to have this issue fixed in our next update.
If you omit the option -DGNULIB_NAMESPACE=gnulib to the gnulib build, then the issue isn't seen. (I don't know if it's possible for you to build it this way.)
Kittur_G_Intel
Thanks Melanie, as always.  I'll monitor the issue and keep the @kehoste updated on the release with the fix when out - appreciate much.
Cheers,
Kittur
Kittur_G_Intel
Just letting you know that this issue is fixed in the 16.0.3 (update 3) release that was out this week which you can download from the Intel Registration Center and  test it out, thanks.
Kittur
