Intel compiler: icpc (ICC) 17.0.2 20170213
g++: g++ (GCC) 5.4.0
clang++: clang version 3.5.2
The following code compiles with g++ and clang++ but not with the intel compiler (using -std=c++14):
using tuple_type = decltype(std::make_tuple(3)); constexpr tuple_type const_tuple0(std::make_tuple(3)); constexpr tuple_type const_tuple1 {std::make_tuple(3)}; constexpr tuple_type const_tuple2 = std::make_tuple(3);
With c++14 we have the possibility to generate and modify compile-time tuples. Unfortunately the intel compiler doesn't seem to like this and complains with
error: expression must have a constant value
for all three statements. Further investigation showed that any constexpr function returning a tuple won't compile. Returning user-defined constexpr classes from constexpr functions works. So there seems to be a problem in returning constexpr tuples.
I can reproduce the errors with 17.0 but it compiles cleanly with 18.0 (currently in beta). Would you be able to use that instead?
