Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
Getting C++11 to work in XCode.
andersgsjogren
I'm trying to compile and link a simple program testing some C++11 features.
main.cpp:[cpp]#include \<mutex\>
#include \<memory\>
#include \<iostream\>
using namespace std;
mutex m;
int main(int argc, const char * argv[])
    lock_guard\<mutex\>l(m);
    unique_ptr\<string\> sp(new string("Hello world"));
    cout \<\< *sp \<\<  endl;
    return 0;
}[/cpp]
Running $icpc main.cpp -std=c++0x yields: main.cpp(9): catastrophic error: cannot open source file "mutex".
If I'm correct, icpc uses the c++ standard library of gcc, which by default is an old 4.2, even on an up-to-date OS X 10.8.
After installing gcc 4.7 from macports, the following worked: icpc main.cpp -std=c++0x -gcc-name=/opt/local/bin/gcc-mp-4.7 .
My problem now is to try and get it to compile in XCode. After switching the compiler to XE 13.0 and selecting -std=c++0x  I add -gcc-name=/opt/local/bin/gcc-mp-4.7 to "Additonal C options". I then get a compilation error "file '/Applications/Xcode.app/Contents/Developer/usr/bin/opt/local/bin/gcc-mp-4.7' not found, generated based on '-dev-usr-root /Applications/Xcode.app/Contents/Developer/usr'". Apparently /Applications/Xcode.app/Contents/Developer/usr/bin/ is appended to the paths.
Trying to work-around it by adding a soft-link to /opt at /Applications/Xcode.app/Contents/Developer/usr/bin/opt improves the situation, but then instead I get catastrophic error: cannot open source file "mutex". I tried adding -gxx-name=/opt/local/bin/g++-mp-4.7 without any improvement.
A related post seems to have succeeded, but it doesn't seem to work for me on OS X 10.8, XCode 4.6.1 and ICC 13.0.2.
It would be greatly appreciated if you could post a step-by-step instruction of how to get C++11 working in XCode with XE 13, using a recent libstd++ and/or libc++. Right now, this is really a show-stopper for me using the intel compiler suite.The best thing would certainly be if you could make it work out of the box with libc++.
SergeyKostrov
Valued Contributor II
>>...$icpc main.cpp -std=c++0x yields: main.cpp(9): catastrophic error: cannot open source file "mutex"... Usage of Intel C++ compiler option -std=c++0x doesn't mean that the compiler will "emulate" a content of "mutex" header file. There are two reasons for that compilation error: - "mutex" header file doesn't exist on your system ( take a look at a ../thr sub-directory ) - a path to a directory where "mutex" header file is located is still Not valid I don't have a system with a Mac OS but I could verify your test on a WIndows 7 Professional OS with Intel C++ compiler v13 update 2.
SergeyKostrov
>>... I could verify your test on a WIndows 7 Professional OS with Intel C++ compiler v13 update 2... The test case was successfully compiled with VS 2012 because it is the only VS version with std threading support. But it has some problerm with: ... cout << *sp << endl; ... and it crashes when I tried to execute the test case.
andersgsjogren
Thanks Sergey for the input.
No, I guess it only enables to core language definition of C++11, but not the standard library (which contains <mutex>).
Correct me if im wrong: My understanding is that icc does not have an own standard library implementation, but uses libstd++ (or possibly libc++?) and that it gets the settings/location of that by calling gcc/clang. Thus, as mentioned in the original post, the command line version compiles when I execute icpc main.cpp -std=c++0x -gcc-name=/opt/local/bin/gcc-mp-4.7, which is a version that has C++11 support.
My real question is: Given an unmodified installation of the most recent versions of OS X, XCode and XE/ICC, how do I get icpc in XCode to compile arbitrary C++11 code that relies on C++11 standard library features (such as mutex from <mutex> or unique-ptr from <memory>. The included code is just an example.
This is really mostly a question on:
  1. How is C++11 standard library setup recommended to be done in icpc on OS X (my solution is macports installation of gcc 4.7 and explicit usage of it, but is there some better/supported way)?
  2. Can one get libc++ (used by Apple) to work instead of libstdc++ (from GCC) as standard library implementation? That might increase compatibility with other Apple related code and wouldn't rely on a non-standard component (gcc 4.7)?
  3. How do I setup the XCode enviroment to make the above work, i.e. to include C++11 standard library header files and link to that C+11 standard library?
andersgsjogren
I've verified that the code compiles an runs just fine on GCC 4.7.3 (installed from macports), OS X 10.8, XCode 4.6.1 and ICC 13.0.2. It's all standard c++11 code, so if it doesn't compile and run, it seems like a bug!?
