Intel® C++ Compiler
7833 Discussions
Getting segmentation fault for no reason.
Jon_P_
I am running on RHE6.7 which comes with gcc 4.4.7. My source code that requires c++11 compatible compiler, so I have downloaded gcc 4.8.2. I am able to compile with gcc 4.8.2 and run.
The Intel compiler completes without any error but when I run the output... I get a segmentation fault. I also get a segmentation fault if I compile HelloWorld.cpp (only when specifying version of 4.8.2), see below:
$ /opt/rh/devtoolset-2/root/usr/bin/g++ HelloWorld.cpp
$ ./a.out
Hello World!
$ icpc HelloWorld.cpp
$ ./a.out
Hello World!
$ icpc -gcc-name=/opt/rh/devtoolset-2/root/usr/bin/gcc HelloWorld.cpp
$ ./a.out
Segmentation fault
Does anyone know what I is happening or what I am doing wrong? Your help will be much appreciated.
Viet_H_Intel
Hi Jon,
Which compiler version are you using. I couldn't reproduce the error with 17.0.4
vahoang@orcsle100:/tmp$ which gcc
/cts/tools/gcc/gcc-4.8.1/bin/gcc
vahoang@orcsle100:/tmp$ icpc -gcc-name=/cts/tools/gcc/gcc-4.8.1/bin/gcc hellow.cpp && ./a.out
Hello, World!
vahoang@orcsle100:/tmp$ cat hellow.cpp
#include <iostream>
using namespace std;
int main()
    cout << "Hello, World!" << endl;
    return 0;
vahoang@orcsle100:/tmp$ cat /etc/redhat-release
Red Hat Enterprise Linux Workstation release 6.0 (Santiago)
vahoang@orcsle100:/tmp$ icc -V
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.4.196 Build 20170411
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
Viet Hoang
Yuan_C_Intel
Hi, Jon
Please also check your glibc version:
$ ldd --version
If you are using a newer version gcc, you'd better not use too old glibc which are incompatible.
Yolanda
Jon_P_
- Hoang and Chen
$ icc -V
$ ldd --version
ldd (GNU libc) 2.12
^ so it looks like my glibc is pretty old and should update it.
Viet_H_Intel
Hi Jon,
Even I have the same glibc and ICC version but I still couldn't reproduce it at my end.
vahoang@orcsle100:/tmp$ ldd --version
ldd (GNU libc) 2.12
Hello, World!
Can you run it under debugger?
Viet Hoang
Jon_P_
Unfortunately, there is no change and no additional information with running with debugger.
Viet_H_Intel
Did you compile with -g? Can you try:  strace -f -o /tmp/st.out ./a.out and look at the output to see if there are any errors?
Viet Hoang
Jon_P_
I did compile with -g
I have output from using icc without specifying new version of gcc (working) and output with specifying new version (broken). The last few lines are as follows.
10349 close(3)                          = 0
10349 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaaaba08000
10349 mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaaaba09000
10349 arch_prctl(ARCH_SET_FS, 0x2aaaaba08b40) = 0
10349 mprotect(0x2aaaaba06000, 4096, PROT_READ) = 0
10349 mprotect(0x2aaaab7f9000, 16384, PROT_READ) = 0
10349 mprotect(0x2aaaab257000, 4096, PROT_READ) = 0
10349 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaaaba0b000
10349 mprotect(0x2aaaaafb6000, 28672, PROT_READ) = 0
10349 mprotect(0x2aaaaacca000, 8192, PROT_READ) = 0
10349 munmap(0x2aaaaaacd000, 104151)    = 0
10349 fstat(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 2), ...}) = 0
10349 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaaaaacd000
10349 write(1, "Hello World!\n", 13)    = 13
10349 exit_group(0)                     = ?
10349 +++ exited with 0 +++
6634  close(3)                          = 0
6634  mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaaaba08000
6634  mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaaaba09000
6634  arch_prctl(ARCH_SET_FS, 0x2aaaaba08b40) = 0
6634  mprotect(0x2aaaaba06000, 4096, PROT_READ) = 0
6634  mprotect(0x2aaaab7f9000, 16384, PROT_READ) = 0
6634  mprotect(0x2aaaab257000, 4096, PROT_READ) = 0
6634  mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaaaba0b000
6634  mprotect(0x2aaaaafb6000, 28672, PROT_READ) = 0
6634  mprotect(0x2aaaaacca000, 8192, PROT_READ) = 0
6634  munmap(0x2aaaaaacd000, 104151)    = 0
6634  --- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0xffffffffffffffe8} ---
6634  +++ killed by SIGSEGV +++
jimdempseyatthecove
Black Belt
While this is a C++ forum, your debug printouts look suspiciously like Fortran.
The failure is occurring on an fstat(1, ...
Which is a status on the console unit number (1).
Do you happen by chance have a FILE.1 or environment variable FORT1=xxx in the failing configuration?
Either would redirect unit 1 to somewhere else (or possibly to nowhere).
Jim Dempsey
Jon_P_
Jim,
There is no FILE.1 or environmental variable FORT1 anywhere.
Viet_H_Intel
I think the problem happened with mummap () called. And the SEGV may generate if  address addr not multiple by the page size.
Do you know what your page size is?
$getconf PAGESIZE
So far, I couldn't reproduce it at our end to investigate further.
Is it  possible for you to download different version of GCC and see if still occurs?
Viet Hoang
Jon_P_
Hoang,
My page size:
$ getconf PAGESIZE
4096
I will work with the Admins on getting a different version of gcc to see if that will help.
Thanks!
Viet_H_Intel
Can you generate an assembly file and provide it to us?
$icpc -gcc-name=/opt/rh/devtoolset-2/root/usr/bin/gcc  HelloWorld.cpp -S -O2
there should be a HelloWorld.s
Viet Hoang
Jon_P_
I was able to get a different version of gcc version 6.1.0. I am able to compile and run with that.
$ icpc -gcc-name=/cm/local/apps/gcc/current/bin/gcc HelloWorld.cpp
$ ./a.out
Hello World!
$ /cm/local/apps/gcc/current/bin/gcc --version
gcc (GCC) 6.1.0
I also ran the command with with the 'broken' compiler setting....
The first time I ran it, ./a.out actually ran and printed "Hello World!", however, the second time it continued to give segmentation fault. The assembly file created during 'segmentation fault' and 'Hello World!' is identical.
Viet_H_Intel
Hi Jon,
I looked at your assembly. It looked ok to me. Then I generated an executable from it. It ran successfully. (I ran it several times)
vahoang@orcsle100:/tmp$ icc HelloWorld.s (your assembly file)
vahoang@orcsle100:/tmp$ ./a.out
Hello World!
If the compiler generated wrong code, then I should have seen the SegFault. So, I think something in your ENV caused the SegFault rather than the compiler.
One more thing you can try is to take a.out to another system to see if it works.
Viet Hoang
