Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
Header File Modifications and Recompilation Trouble Using XE 14 and Xcode 5
Dan1
Hi -
I am using the combination of the C++ Compiler XE 14.0 Update 1 and Xcode 5.0.2 running on OS X 10.9.1 and am seeing compilation issues (which is reproducible among 2 of my other colleagues on similar setups).
The problem is the following: any changes to header files within a project are not treated accordingly and recompilation of respective compilation units and relinking of products is not carried out.
Workarounds to this (all impractical) are:
  • clean the project and rebuild everything
  • ​close the Xcode project and re-open it
  • close Xcode and relaunch it
A very simple Xcode project was created that demonstrates the issue.
  1. Create a new Xcode, blank.
  2. Create a C++ library target - dynamic.
  3. Add two files, e.g. a foo.cpp and a foo.h file
  4. Set the compiler to Intel's C++ XE 14
  5. Build - all is well
  6. Build again - no extra work, all is well
  7. Modify the foo.h file
  8. Build - fails to rebuild correctly.
A link to a sample Xcode project can be found here:
https://github.com/surething/DependencyTest
Once built, any changes to the *.h file does not incur a recompilation and a relink of the generated *.dylib. This issue does not occur when using Apple's LLVM compiler.
Does anyone know of potential solutions to this?
VERA_F_Intel
Hello Dan,
Thanks for reporting this issue. I've reported about it to the developers, and I'll keep this thread updated with any news from them.
Tracking ID:  DPD200252300
Vera
VERA_F_Intel
Hello Dan,
This is not related to the compiler. We reported this issue to Apple. This behavior will be corrected in future versions of Xcode.
Vera
Dan1
Hi Vera,
I then look forward to the next release of Xcode :) do you know if the fix will be available in Xcode 5.1?
Dan;
VERA_F_Intel
Dan,
No, the exact version unknown to us now. But I will write here about any news regarding this.
Denis_B_Intel1
The issue is resolved in Xcode 6, headers are recompiled there with C++ Compiler XE 15.0.
Denis
