I am trying to compile HDF5 with Intel mpi. It is needed by some other software that I am compiling for my Intel Distribution conda python environment. I am trying to use conda to contain everything -- I think the important details are below. I probably have some redundant variable declarations because I have tried SO many combinations:
export NPROCS=4 export SRCBUILDDIR=$HOME/some/tmp/build/dir export INSTALL_PATH=$HOME/anaconda3/envs/HDF5env export INTEL_ROOT="${HOME}/intel/compilers_and_libraries_2018.3.222/linux" export INTEL_BIN="${INTEL_ROOT}/bin/intel64" export INTEL_LICENSE_FILE=${INTEL_ROOT}/licenses:${HOME}/intel/licenses export INTEL_MPI_ROOT=${INTEL_ROOT}/mpi export MKLROOT="${INTEL_ROOT}/mkl" export MKLPATH="${MKLROOT}/lib/intel64" export PATH="${MKLROOT}/bin:${INTEL_MPI_ROOT}/intel64/bin:${INTEL_BIN}:${PATH}" # I am sure that I am doubling up on some env vars by calling the scripts below export COMPILERVARS_ARCHITECTURE="intel64" export COMPILERVARS_PLATFORM="linux" ${INTEL_ROOT}/bin/compilervars.sh ${INTEL_ROOT}/mkl/bin/mklvars.sh ${INTEL_ROOT}/mpi/bin64/mpivars.sh # Not sure if this is the proper way to do this, but it works with my other code that needs MKL MKLLIBS="-Wl,--no-as-needed,-L${MKLROOT}/lib/intel64 -lmkl_rt -ldl" export CPATH="$CPATH:${INTEL_ROOT}/mkl/include:${INTEL_ROOT}/mpi/intel64/include:${INTEL_ROOT}/compiler/include:${MEEP_INSTALL_PATH}/include:${MEEP_INSTALL_PATH}/include/gsl:${MEEP_INSTALL_PATH}/lib/python3.6/site-packages/mpi4py/include:${MEEP_INSTALL_PATH}/lib/python3.6/site-packages/numpy/core/include/numpy" export LIBRARY_PATH="${INSTALL_PATH}/lib:${INTEL_MPI_ROOT}/intel64/lib:${INTEL_MPI_ROOT}/mic/lib:${INTEL_ROOT}/compiler/lib/intel64_lin:" export LD_LIBRARY_PATH="${LIBRARY_PATH}:$INSTALL_PATH/lib" export LD_RUN_PATH="${LIBRARY_PATH}:$INSTALL_PATH/lib" # Linkers and Compilers export AR=${INTEL_BIN}/xiar export LD=${INTEL_BIN}/xild export CC=mpiicc export CXX=mpiicpc export MPICC=mpiicc export MPICXX=mpiicpc export F77=mpiifort export F9X=mpiifort export FC=mpiifort export I_MPI_CC=icc # Flags export CFLAGS="-O3 -no-prec-div -ip -ipo -march=core-avx2 -xHost -xCORE-AVX2 -m64 -shared-intel ${MKLLIBS}" export CXXFLAGS="${CFLAGS}" export FFLAGS="-fPIC ${CFLAGS}" export LDFLAGS="$MKLLIBS" export HDF5_MPI="ON" export I_MPI_SHM_LMT=shm set +e if [ "$COMPILERS" = "intel" ]; then # The -fp-models are helpful for the other code I am compiling, thought they would be useful here... CFLAGS="-ip -ipo $CFLAGS -fp-model source -fp-model strict"; fi cd $SRCBUILDDIR wget http://www.zlib.net/zlib-1.2.11.tar.gz rm -r zlib-1.2.11 && tar -zxvf zlib-1.2.11.tar.gz || tar -zxvf zlib-1.2.11.tar.gz rm zlib-1.2.11.tar.gz cd zlib-1.2.11 CFLAGS="$CFLAGS" ./configure --prefix=${SRCBUILDDIR}/zlib-1.2.11 make make check make install # Download hdf5 from here HDFVERSION="hdf5-1.10.2" cd $SRCBUILDDIR wget "https://support.hdfgroup.org/ftp/HDF5/releases/hdf5-1.10/$HDFVERSION/src/$HDFVERSION.tar.bz2" rm -r "$HDFVERSION" && tar -xjf "$HDFVERSION.tar.bz2" || tar -xjf "$HDFVERSION.tar.bz2" export RUNSERIAL="mpirun -np 1" export RUNPARALLEL="mpirun -n 4" export I_MPI_SHM_LMT=shm ### BUILD HDF5 Parallel cd $HDFVERSION CFLAGS="$CFLAGS" ./configure --prefix="$INSTALL_PATH" --enable-parallel --enable-shared \ --with-zlib="$INSTALL_PATH" --enable-static --enable-fortran --enable-hl make -j $NPROCS # Most of the tests pass, but some don't and hang up the script # make -k -j $NPROCS check make -j $NPROCS install # The only way I have found to force pip to use Intel Compilers is to set the LDSHARED var inline LDSHARED="mpiicc -fp-model source -fp-model strict $CFLAGS -L{$MEEP_INSTALL_PATH} -lhdf5 \ -I${INSTALL_PATH}/include" CPPFLAGS="-E $CPPFLAGS" HDF5_DIR=${MEEP_INSTALL_PATH} \ pip -v install --force-reinstall --no-deps --ignore-installed --no-cache-dir --no-binary=h5py h5py; # ........ Compile some more code that uses parallel HDF5 and parallel h5py below .......... # for example, gsl and the MEEP suite
Everything compiles, MOST of the hdf5 tests pass, I will edit or update when I go back to look up where it fails.
h5py is where the error shows up and I don't know why. Whenever any code tries to import h5py, or when I test the module load, I get:
(HDF5env) user@localhost:~$ python -m h5py Traceback (most recent call last): File "/home/user/anaconda3/envs/HDF5env/lib/python3.6/runpy.py", line 183, in _run_module_as_main mod_name, mod_spec, code = _get_module_details(mod_name, _Error) File "/home/user/anaconda3/envs/HDF5env/lib/python3.6/runpy.py", line 142, in _get_module_details return _get_module_details(pkg_main_name, error) File "/home/user/anaconda3/envs/HDF5env/lib/python3.6/runpy.py", line 109, in _get_module_details __import__(pkg_name) File "/home/user/anaconda3/envs/HDF5env/lib/python3.6/site-packages/h5py/__init__.py", line 26, in <module> from . import _errors ImportError: cannot import name '_errors'
I suspect that it might have something to do with the failing HDF5 tests? I have scoured the internet. setting the HDF5_DIR var in the pip command is the only proposed solution I have found that works for others with this error, but does not work for me.
Thanks in advance.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
