Intel® C++ Compiler
7956 Discussions
Help: OpenMP can't get multiple threads, max num thread is always 1
Weiguang_Y_
I was trying to  add a piece of C++ code using openmp  to an old program which uses c++, c and Fortran. The problem is that  omp_get_max_threads() always returns  1. Although I have explicitly  set  omp_set_dynamic(0) and  omp_set_num_threads(4), I still get 4 same thread number from the parallel region. For example, I linked an openmp hello world to the old codes. The program displayed 4 hello world messages from thread 1 instead of from thread 0,1,2,3 and 4.  However, the openmp hello world code worked correctly on the same machine when it was separated from the program.
The original makefile doesn't use openmp.  I just simply added flag openmp to the corresponding CXX compiler and linker as follows:
CXX = icpc -pthread -->  CXX= icpc -pthread -openmp
LINK_EXE =$CXX -thread -o --> LINK_EXE =$CXX -thread -openmp -o
I am wondering whether there is anything wrong in my makefile.
Thanks  for your time and help!
SergeyKostrov
Valued Contributor II
Please upload a test case and I could verify it on Evy Bridge ( 4 CPUs / 8 cores ) and Pentium 4 ( 1 CPU ) systems. Thanks in advance.
