I am doing some heavy template metaprogramming, so perhaps the complete templates are getting long. After adding in some namespaces, I am now getting the error on debug compilation:
Debug generation WARNING: Debug information will be incomplete
due to a symbol or type CodeView record exceeding the maximum
record length of 65535. In some cases you can avoid this error
by decreasing the length of identifiers.
The current member is: arg<1>.value
Strangely, it seems to work fine when I did the debug build from within Visual Studio.
Is there any setting or workaround/compiler setting for this? Or should I just get rid of the namespaces, etc.?
Jesse
/Yc:\working\etk_binaries\etk_headers.pch"
Two questions.
1. within VS IDE, it builds ok. Could you paste the compile-option here?
2. above option "/Yc:...", is it used for compilingthe file that gives the warning below?
Jennifer
Two questions.
Jennifer
Attempt 1, with "nmake" (generated from cmake) and the command flags "/MP /Qstd:c++0x /YX /Fpc:\working\etk_binaries\etk_headers.pch"
Note the /YX and /Fpc: This used to work with intel 11.0 (though perhaps I was using things wrong).
=>THIS CAUSES NO ERRORS, but says that '/YX' is being deprecated, and I read in docs that it is /Yc replaces it. This also creates a precompiled header file.
Attempt 2: same thing, but now following the deprecation advice followed. "nmake" and the flags "/MP /Qstd:c++0x /Yc:\working\etk_binaries\etk_headers.pch"
But now that I doublecheck it, I don't think that it is creating the precompiled headers with the new setting. So this is strange . Am I using the precompiled headres wrong and could that cause problems?
What is the easiest way to get precompiled headers always working with a named file and debug information put into it? I really had a lot of trouble figuring out all the settings in the documentation.
Attempt 3: using the cmake to generate visual studio files, it compiles without problems and has the following command line. However, I notice now that it isn't generating precompiled header usage here, so this may be a red herring.
/c /Od /I "C:workinglibrariesboost" /I "C:workinglibrariescoin" /I "C:workinglibrariesetk" /I "C:workinglibrariestinyxpath" /I "C:workinglibrariesmumpsmumps" /I "C:workinglibrariesfadbad" /I "C:workinglibrariesloki" /I "C:workinglibrariesknitro" /I "C:appsIntelCompiler11.151mklinclude" /I "c:appsmpich2include" /I "C:workinglibrariesquantlib" /D "WIN32" /D "_WINDOWS" /D "_DEBUG" /D "BOOST_HAS_TR1" /D "HAVE_MA27" /D "HAVE_MC19" /D "HAVE_MUMPS" /D "COIN_HAS_MUMPS" /D "CMAKE_INTDIR="Debug"" /D "_MBCS" /EHsc /RTC1 /MDd /GS /fp:fast /Fo"etk_template.dirDebug" /W3 /nologo /Zi /TP /Zm1000 /MP /Qstd:c++0x
Thanks for your help!
Two questions.
Jennifer
One comment I had from my previous code: I had the following at the top of my cpp file:
#include
#pragma hdrstop
...which I thought meant I didn't need to put in the name of a stdafx.hpp style file.
But I took my project and went through the visual studio GUI choosing my equivalent to stdafx. (in c:workinglibrariesetketkall.hpp), etc. The precomplied headers didn't seem to work, but here is the command line:
/c /Od /I "C:workinglibrariesboost" /I "C:workinglibrariescoin" /I "C:workinglibrariesetk" /I "C:workinglibrariestinyxpath" /I "C:workinglibrariesmumpsmumps" /I "C:workinglibrariesfadbad" /I "C:workinglibrariesloki" /I "C:workinglibrariesknitro" /I "C:appsIntelCompiler11.151mklinclude" /I "c:appsmpich2include" /I "C:workinglibrariesquantlib" /D "WIN32" /D "_WINDOWS" /D "_DEBUG" /D "BOOST_HAS_TR1" /D "HAVE_MA27" /D "HAVE_MC19" /D "HAVE_MUMPS" /D "COIN_HAS_MUMPS" /D "CMAKE_INTDIR="Debug"" /D "_MBCS" /EHsc /RTC1 /MDd /GS /fp:fast /Yc"c:workinglibrariesetketkall.hpp" /Fp"etk_template.dirDebug/etk_template.pch" /Fo"etk_template.dirDebug" /W3 /nologo /Zi /TP /Zm1000 /MP /Qstd:c++0x
...and here is the output:
1>------ Build started: Project: etk_template, Configuration: Debug Win32 ------
1>Compiling with Intel C++ 11.1.051 [IA-32]... (Intel C++ Environment)
1>etk_template.cpp
1>etk_template2.cpp
1>using typeof emulation
1>C:workinglibrariesetketk/statistics/ublas_statistics.hpp(87): catastrophic error: error while deleting file "etk_template.dirDebugetk_template.pchi"
1> } } }//ublas
1> ^
1>
1>
1>Debug generation WARNING: Debug information will be incomplete
1>due to a symbol or type CodeView record exceeding the maximum
1>record length of 65535. In some cases you can avoid this error
1>by decreasing the length of identifiers.
1>The current member is: arg<1>.value
1>icl: error #10298: problem during post processing of parallel object compilation
1>Build log was saved at "file://c:workinglibrariesexamplesetk_templatebuild_visualstudioetk_template.dirDebugBuildLog.htm"
1>etk_template - 2 error(s), 0 warning(s)
65535 characters in a record seems a bit excessive even for rather large numbers of nestedtemplates. This error may be due to something else.
I seem to recall a problem that was "fixed" some time ago relating to templates with comments on the close brace line and in particular when the comment had some format or placement quirk (which I do not recall at this time). If you have nothing better to do, try removing the comment from this line:
1> } } }//ublas
(or put a line break after the last }
Jim Dempsey
1> } } }//ublas
Jim Dempsey
Now, if I could only figure out the mess of settings used in precompiled headeres... creation vs. use, etc. It is all so confusing. Right now I am using the following on the nmake command line:
"/Yd /Yc:\working\etk_binaries\etk_headers.pch"
Will that create/update the header file if required and allow me to reuse it between different .cpp being compiled at the same time (if they all used the #pragma hdrstop after the same header)?
1> } } }//ublas
Wow, good catch with good eyes. THANKS!
For pch use, you should have one file .cpp with includes to create the .pch file with /Yc, other .cpp files can use it with /Yu.
All the .cpp files should have the common includes at the begining with the same order so one .pch can be used by all others.
Jennifer
1> } } }//ublas
Jennifer
If I have "Yc" in the compilation of a .cpp file and their have been no changes to the header files, will it always recompile it or just use it? Can I just put "Yc" on all of my .cpp files and get the same usage?
Also, I have a huge number of libraries being used and almost all of them are templated (I am using 1/2 of boost). There are probably only a couple non-templated funcitons and classes out of tens of thousands. Am I going to get much out of precompiled headers (since I understand that templated functions/classes are only partially compiled/parsed until instantiation)?
Not having a failing case here I can only throw out suggestons (as I did with the } } }//barf)
If the faulting text "} } }//barf" is generated by the precompiled headers (and you are editing the output) then I suggest you add something to the appropriate header file such that something additional is added there.
As I said in an earlier post, I suspect the problem in the compilerwas a buffer or line alignment issue where the boundary occured in the "} } }//barf" at a sensitive position. Adding code may move the position of the "} } }//barf" and thus hide the problem.
Jim Dempsey
Jim Dempsey
Sorry, I guess I miscommunicated before. Your previous suggestion solved the problem beautifully! Seems that you can't have comments and a lack of a newline in the last header before #pragma hdrstop.
My responses after this were just to try and figure out how to use precompiled headers and whether they will do my templated-centric code. I should have posted a separate question.
Thanks for your help.
