I installed the initial release of Intel® oneAPI 2021.1.
I have some difficulties regarding codes that were working correctly on previous intel compilers and are working with no issue on other GNU, CLANG, ... C++ compilers
For example,
#include <iostream>
#include <sstream>
#include <string>
#define SNUM(x) static_cast<std::ostringstream &>(std::ostringstream() << std::dec << x).str()
int main() {
int n = 100;
std::string s = "matrix (of size N=" + SNUM(n) + ")";
std::cout << s << std::endl;
this sample is working correctly on a wide range of compilers including other Intel compilers but with oneAPI 2021.1 C++ Compiler on macOS is failing with:
test.cpp(7): error: expression must be an lvalue
compilation aborted for snum.cpp (code 2)
Host info:
>> sw_vers
ProductName: macOS
ProductVersion: 11.1
BuildVersion: 20C69
Compiler info:
>> icpc --version
icpc (ICC) 2021.1 Beta 20201112
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
Can you advise me if there is any compatibility issue on macOS?
@Viet_H_Intel thanks for checking this issue. I checked it again and figured out the compiler error is correct and this piece of code is wrong. Apparently, the older compilers did not capture it.
The macro should change to,
#define SNUM(x) static_cast<const std::ostringstream &>(std::ostringstream() << std::dec << x).str()
and it is working as supposed.
We tried the same sample provided by you on our environment with the same ICPC compiler, but we cannot see the errors.
So we are forwarding this issue to the SME.
Also as this thread is more related to the Intel C++ compiler we are moving this thread to the Intel C++ forum.
Warm Regards,
Abhishek
Your answer is irrelevant to the question!
It seems like a configuration issue. Clang++ (12.0) gives an error with -std=c++11
$ clang++ t.cpp -std=c++11
t.cpp:7:48: error: non-const lvalue reference to type 'basic_ostringstream<...>' cannot bind to a temporary of type 'basic_ostringstream<...>'
t.cpp:4:17: note: expanded from macro 'SNUM'
1 error generated
$ clang++ t.cpp -std=c++98
$ /opt/intel/oneapi/compiler/2021.1.1/mac/bin/intel64/icpc t.cpp -std=c++11
compilation aborted for t.cpp (code 2)
$ /opt/intel/oneapi/compiler/2021.1.1/mac/bin/intel64/icpc t.cpp -std=c++98
Thanks, @Viet_H_Intel.
It is very interesting, I did not notice this,
g++ --version
Configured with: --prefix=/Library/Developer/CommandLineTools/usr --with-gxx-include-dir=/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/c++/4.2.1
Apple clang version 12.0.0 (clang-1200.0.32.28)
Target: x86_64-apple-darwin20.2.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
>> g++ test.cpp
>> ./a.out
matrix (of size N=100)
but as you mentioned with c++11
>> g++ -std=c++11 test.cpp
test.cpp:7:41: error: non-const lvalue reference to type 'basic_ostringstream<...>' cannot bind to a temporary of type 'basic_ostringstream<...>'
test.cpp:4:17: note: expanded from macro 'SNUM'
1 error generated.
@Viet_H_Intel I tried `g++ -std=c++98 test.cpp` and it is working correctly.
>> ./a.out
I am going to close this issue.
