Intel® C++ Compiler
How are we supposed to migrate from #pragma simd?
roger567
If I try
double* ptr1;
double* ptr2;
__assume_aligned(ptr1, 64);
__assume_aligned(ptr2, 64);
#pragma simd
for (int i=0; i<n; ++i)
   ptr1 = ptr2;
it will vectorise the loop with aligned access, but gives a warning that #pragma simd is deprecated.
If I swap "simd" for "vector aligned", it does not vectorise and  the optimisation report says "use the simd directive".
The documentation for #pragma simd (https://software.intel.com/en-us/cpp-compiler-developer-guide-and-reference-simd) doesn't mention deprecation or any alternatives.
Is there any documentation/articles that tells us how we are supposed to do this these days?
AbhishekD_Intel
You can follow this link which will help to understand including SIMD in your codes.
I hope it will solve your problem.
-Abhishek
AbhishekD_Intel
Can you please send us the details of the compiler which you are using?
-Abhishek
roger567
Hi Abhishek,
I am using:
Microsoft Visual Studio Community 2017 Version 15.9.18
VisualStudio.15.Release/15.9.18+28307.960
Intel® Parallel Studio XE 2019 Update 5 Composer Edition for C++ Windows*   Package ID: w_comp_lib_2019.5.281
Intel® Parallel Studio XE 2019 Update 5 Composer Edition for C++ Windows* Integration for Microsoft* Visual Studio* 2017, Version 19.0.6.15
AbhishekD_Intel
-Abhishek
jimdempseyatthecove
At issue here is the pointers you have declared may overlap with respect the SIMD vector width. Use of #pragma simd stated "you don't care if they overlap, vectoreize regardless of possibility of overlapping". What you need is a means of assuring the compiler that these pointers will not point to memory that will overlap when used by a vector read from one, operator, vector write to the other. For this, there is the restrict keyword.
double* restrict ptr1; // *** or __restrict depending on compiler vendor and/or option
double* restrict ptr2; // *** or __restrict depending on compiler vendor and/or option
   ptr1 = ptr2;
Note, the availability of the restrict keyword may depend upon the choice of C++ standard selection or other compiler option.
https://software.intel.com/en-us/cpp-compiler-developer-guide-and-reference-restrict-qrestrict
Additionally, see: https://en.wikipedia.org/wiki/Restrict and https://gcc.gnu.org/onlinedocs/gcc/Restricted-Pointers.html
You may need to use __restrict, __restrict__, __declspec(restrict)
Jim Dempsey
Vladimir_P_1234567890
you can try to use "#pragma omp simd" instead of "#pragma simd".
Vladimir
roger567
Thanks guys,
The documentation link was what I was looking for - searching the Intel web-site produced great articles from 2013 and prior, but I had no idea what was currently recommended practice.
Jim's restrict option makes the most sense to me, but it drives Intellisense and Resharper crazy, even though it compiles and works.
So I will switch to Vladimir's omp simd for now and hope VS catches up with restrict.
Thanks again
Roger
AbhishekD_Intel
Thanks, Roger for your confirmation can we close this thread?
You are always welcome to post a new thread if you have any issues.
-Abhishek
