Intel® C++ Compiler
7929 Discussions
How can I work with local arrays and threads
Eugin_B_
Hi All!
I have VS2013+Intel Parallel Studio XE 2015+TBB 4.3
My current code has many functions that has local stack allocations by exampe
void fnc() {
  int arr[1024];
when I started use fnc() in parallel for (it is some form of parallel execution) I got bad concurrent perfomance according to VTune analyser
I done some replacement for the code: int *arr = malloc(sizeof(int) * 1024). malloc I got versus from tbb of course. In the result I got very good concurrent execution. Really I can't understand why local stack allocation has concurrency problems. Can anyone describe the problem? Has this issue easy solution?
Thanks! Sorry for my bad english!
jimdempseyatthecove
Black Belt
If the speed differs, but the results are correct, then suspect it is an alignment issue. You can align the stack local array using:
Windows* OS:
__declspec(align(16)) int arr[1024];
Linux* OS:
int arr[1024] __attribute__((aligned(16)));
FWIW I whish the standards committee would adopt a uniform way of doing this.
Jim Dempsey
jimdempseyatthecove
Black Belt
Thanks for pointing this out to me. Now I can start modernizing my alignment directives/attributes.
It still bugs me that C++11 and C11 use different keywords, same issue with __int32, int32_t, int32, etc...
Jim Dempsey
Eugin_B_
Thank you for your replies. I tested alignment directives but without any changes in the results.
I tried to create the simple example to show the issue more detailed but I found that all is not so simple and easy. I will investigate it and give you back with additional info if my question still is actual
