Prompt please as correctly it is necessary to write
[bash]#pragma loop count (N)[/bash]Src or Src.
or it is necessary to write as it is specified in Intel C++ Compiler User & Reference Guides:
[bash]#pragma loop_count (N)[/bash]
Why so it is a lot of different interpretations?
Really developers from Intel do not use file WinDef.h or Windows.h where define ?
[bash]#ifndef max #define max(a,b) (((a) > (b)) ? (a) : (b)) #endif #ifndef min #define min(a,b) (((a) < (b)) ? (a) : (b)) #endif[/bash]because of what there is a conflict in #pragma:
[bash]#pragma loop_count min(n), max(n), avg(n)[/bash]Excuse me for my English.
"#pragma loop_count" is an Intel compiler specific pragma, and I would suggest that you use what is documented in the product documentation.
As for the "conflict" with Windows.h, I assume that you are referring to the following warning:
>>>t.c(13): warning #54: too few arguments in macro invocation #pragma loop count min(3), max(10), avg(5)
>>>t.c(13) : warning C4068: unknown pragma t.c(13) : warning C4003: not enough actual parameters for macro 'min'
>>>t.c(13) : warning C4003: not enough actual parameters for macro 'max'
This warning warns the users that min, max, avg when use in this context (with #pragma loop_count) has a different meaning than what is provided in Windows.h You can disable this warning with the option /Qwd54, where the number 54 refers to the identifier of the warning.
Note that Microsoft gives you a similar warnings:
though I am trying ICC 13.0 (beta ATM), but I feel this case doesn't matter.
I have eliminated warning by "/Qwd54" as you suggested.
My question is: When "min", "max" and "avg" are macros from Microsoft's headers, will ICC honour this pragma anyaway?
it's true that both min(...) and max(...) are defined macros inherited by inclusion of "windows.h" ("WinDef.h" to be precise).
This means that the pre-processor will substitute all occurrences of both min(...) and max(...) before invoking the compiler. Hence, if you write something like that:
[cpp]#include... #pragma loop_count min(10), max(100), avg(25)[/cpp]
...the preprocessor will generate this:
[cpp]#pragma loop_count (((10) < ()) ? (10) : ()), (((100) > ()) ? (100) : ()), avg(25)[/cpp]
This is definitely not what you want. On Linux*/Mac OS* X you won't have this problem, by the way.
The correct solution is to use the alternative syntax:
[cpp]#pragma loop_count min=10, max=100, avg=25[/cpp]
Georg Zitzlsberger
- #ifndefmax
- #definemax(a,b)(((a)>(b))?(a):(b))
- #endif
- #ifndefmin
- #definemin(a,b)(((a)<(b))?(a):(b))
- #endif
[bash]#ifndef max #define max(a,b) (((a) > (b)) ? (a) : (b)) #endif #ifndef min #define min(a,b) (((a) < (b)) ? (a) : (b)) #endif[/bash]...
Problems with 'min' and 'max' macros are very old anda couple of years ago I decided to stop using these
macros. On a project I'm currently working two new macros are used instead, like:
#define CrtMin ...
and
#define CrtMax ...
They finally isolated codes from oldissues with classically defined macros.
Sergey
