Intel® C++ Compiler
7956 Discussions
How could I call a function from a DLL compiled by VC++?
Intel_C_Intel
I have a .dll file compiled by VC++.
If I want to call it from VC++, I can define the head as:
Code:
#ifdef __cplusplus
extern "C" {
#endif
BOOL WINAPI GetId(LPTSTR lpOutBuffer, int Mode);
#ifdef __cplusplus
#endif
I call it as follow:
Code:
char Id[50];
memset(Id, '�', 50);
BOOL result = GetId(Id, 0);
if(result)
    CString IdStr;
    IdStr = Id;
    MessageBox(IdStr);
Do you know how could I do the corresponding calling in Intel C++?
JenniferJ
The Intel C++ Compiler is source and binary compatible with VC*++. So you don't need to do any code change in order to use the IntelC++.
Jennifer
